2013 MDX bucks and surges at 40-60 mph. What's the cure??
My wife's MDX fwd, V6... Very noticeable buck and surge when holding a steady pace between 40-60 mph... Transmission works perfectly, upshifts with the paddles, downshifts, everything... I'm thinking either programming, EGR, or the drive-by-wire TPS... Help! I'm tired of it! Ken
When is the last time the ATF was changed? I ask because a TSB came out that covers the 2012-2015s that talks about judders from the transmission (TSBs 16-062 and 063) between 20-60 mph. It is deteriorated ATF that is causing it (early failure due to overheating ATF; TSB lowers the operating temp of the transmission).
Copies of the TSBs can be found here: https://acurazine.com/forums/3g-mdx-...letins-947741/
