'17 MDX Elite/Advance and slow brake 360 degree camera
Old 09-11-2017, 10:25 PM
bailey24's Avatar
Picked up a 2017 MDX a few weeks ago and really like the use of the 360 degree camera, having it come up automatically when the vehicle speed drops below 20 KM/hr. Then when you start rolling again it switches back to your normal view (mine being the nav). My problem is that sometimes when I get in the car and drive and eventually come to a light or stop sign the cameras don't come on and I have to press the "camera" button to enable it and it will work from that point on. Sometimes it does work, other times it wont. I thought it was somehow linked to starting the car and waiting until the dislaimer screen shows the option to press "OK" but that is not the case
I am confident I have it enabled in the vehicle settings but not sure if something else is casuing it. Has anyone else experienced this? If so, I would love to hear from you as to what you did to address the issue
Old 09-12-2017, 10:33 AM
flyboy's Avatar
I have the same issue randomly, I have found no fix other then to just push the camera button
Old 09-12-2017, 10:36 AM
getakey's Avatar
I did not realize there was a setting for it to come on automatically at low speed
Old 09-12-2017, 11:28 AM
bailey24's Avatar
yup. It is located in the display between the speedometer and odometer under 'vehicle settings'. Great feature
Logicwand (10-17-2020)
Old 09-20-2017, 01:41 PM
17X
17X's Avatar
I have same the problem.
Old 09-22-2017, 11:18 PM
GrayFox's Avatar
I found that after fiddling with the options that I needed to start the car moving by FIRST using reverse then slowing down will activate the cameras.
If I start the car and start moving FIRST by using drive ie moving forward then the camera is not activated hen slowing down.
Jerry
Old 09-23-2017, 01:29 PM
RLX-Sport Hybrid's Avatar
Received 1,164 Likes on 536 Posts
I did not know it could do that in the first place. I only use it for parking situations.
Old 09-24-2017, 04:03 PM
getakey's Avatar
I don't see any setting that is activated at "low speed". There is a setting to activate front camera after using Reverse and then the front camera goes off after reaching a speed. I aalso see a setting to tun it on when decelerating. Is that what you are talking about?
Old 09-24-2017, 07:04 PM
getakey's Avatar
ok - I turned on the setting for on during deceleration. It came on at very low speed when coming to a stop. However, it would drive me nuts so I turned it back off.
Fabvsix (09-10-2018)
Old 09-29-2017, 08:45 AM
bailey24's Avatar
lol. I came from a '15 TLX so when I took it for an extended test drive it bugged me a little as it was like noise in my peripheral. But since making pulling the trigger and making the swith, I actually like it. I have an 8 year old child and there are lots of kids around where we live. Being able to see around me as I turn corners at intersections I find it helpful. Also, some tighter areas helps me make sure I don't scratch the lovely 20" rims it came with.
Cheers,
Old 09-08-2018, 02:20 PM
3rd Gear
Lastcalll's Avatar
Acura Deceleration Camera
Jerry
Thanks Jerry... I tested your method and that worked for me. Unfortunately I back my car into the driveway so always leave in drive, not reverse. Quirky for sure. Hopefully this would get sorted out in a software update.
Old 09-08-2018, 03:11 PM
p07r0457's Avatar
just push the camera button?
I hope they do NOT change this function, via software update.
Old 09-08-2018, 06:36 PM
3rd Gear
Lastcalll's Avatar
Agreed. I don’t want them to get rid of this function. I just want it to do what is supposed to do and that is activate the camera when slowing down without having to always press the button.
Old 09-08-2018, 07:18 PM
p07r0457's Avatar
it does work that way... but if your complaint is that it doesn’t come on from “Park” then that isn’t “slowing down”
Old 09-08-2018, 07:28 PM
3rd Gear
Lastcalll's Avatar
No...I don’t mean from park....I actually know the difference between park and slowing down. Anyways I was just sharing a comment about how it doesn’t work in my car on a consistent basis and that hopefully a software update will make it more consistent.
Old 09-08-2018, 09:20 PM
VMDX's Avatar
My new 18 does the same thing. Apparently there are not enough complaints, for Acura to come up with software patch.
Old 09-09-2018, 07:24 AM
4th Gear
19MDXSportHybridAdvance's Avatar
My 19 Hybrid does the same thing. LOVE this feature too!
