15 MDX front struts and brakes replacement. - AcuraZine - Acura Enthusiast Community
Go Back  AcuraZine - Acura Enthusiast Community > Acura MDX Community > 3G MDX Discussion (2014+)
Reload this Page >
Notices
Old 01-07-2019, 03:21 PM
Registered Member
Hi guys, 2015 MDX SHAWD and I am about to replace my front struts due to 1 is leaking oil per the dealer. Has anyone ever done this before and give me some tips/advices? Do I have to replace the stabilizers, do the bolts have to be replace. So far, I only have the front left and right struts awaiting to be purchased.
For the brake rotors and pad, do you recommend buying OEM or something from Ebay or Amazon will do?
Thank you.
Apollo2TheMoon is offline
Old 01-07-2019, 04:36 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
I would avoid buying brakes on eBay. You never know what kind of metal is used on the brakes. Probably pure shit.
gatrhumpy is offline
Old 01-07-2019, 11:58 PM
Registered Member
if needing struts anyways, buy a coilover set up instead?
shenofjo is offline
Old 01-08-2019, 02:24 AM
WTF?
Midnight Mystery's Avatar
Time for full on suspension. Stoptech brakes rotors, Akebono pads, Brembo calipers, coilovers, RSB abd maybe stainless steel braded brake lines for more punch!
Are we taking it this far?!?!?!?
Midnight Mystery is offline
Old 01-08-2019, 12:19 PM
Registered Member
coykiam's Avatar
For Azine? neverrr!!
coykiam is offline
Old 01-08-2019, 01:37 PM
Registered Member
There are many places that sell everything you need. Let the internet be your friend. What you do is largely based on your budget. Calipers? Naw. Discs? Only if yours are warped of gouged. Pads? Again whats your budget and driving style. Struts? Easy to change IF your mechanically inclined and have the proper tools. At a minimum you need a set of spring compressors.
Donn0128 is offline
Old 01-08-2019, 06:16 PM
Registered Member
Thanks bro, appreciate your feedback.
Old 01-08-2019, 06:28 PM
Registered Member
Rockauto alone has probably 50 each different grades and prices of pads and discs foe your car. I did not though see any struts. But Im sure a bit of sweb searching you can find dozens of offerings
Donn0128 is offline
Old 01-09-2019, 09:05 AM
Registered Member
Limiter data but heard good things on bc coil overs
shenofjo is offline
Old 02-12-2019, 12:10 AM
Registered Member
Thank you.
Have you replaced the struts?
I'm supposed to have "gas pressurized shock absorbers (per the VIN decoder)" and "MacPherson strut front suspension (original sticker)". I see some oil leaking from front right shock, not sure if it's also oil filled? Someone please help.
Sparky16 is offline
Old 02-12-2019, 09:19 AM
Registered Member
Yes, I had them replaced.
raheel616
19
11-06-2018 07:43 PM
FZ427
1G TSX Problems & Fixes
11-06-2007 10:13 AM
cmschmie
17
06-11-2006 09:16 PM
dark inspire
21
03-14-2005 04:03 PM
NJtsx
39
01-27-2005 09:52 PM
Quick Reply: 15 MDX front struts and brakes replacement.
