Transmission issue?
Transmission issue?
I was about decided on a 2017 MDX but after additional research I’m finding a lot of complaints about shifting between 1st and 2nd gears being extremely rough. I’d like to hear from owners their thoughts on the issue. Overblown? Big deal? Minor annoyance? Thank you!
More info than you ever wanted:
https://www.piloteers.org/threads/zf...praise.114682/
https://www.mdxers.org/threads/2017-...-harsh.171528/
Overblown. Yes it’s an issue but it’s not an issue on every 2017. Is the vehicle you are looking at still under factory warranty? Software update and ecu reset seems to do the trick and is covered under warranty.
I mentioned a rough shift from 4-5 (or maybe 3-4?) shift and received a software update. I could reproduce it every time by accelerating to 25 MPH, then letting off the accelerator. The vehicle would then buck into the next gear.
The software update fixed it completely. We have a 2017, BTW.
By and large the ZF9 speed issues have been resolved with software updates. The basic transmission had been used in a wide range of cars over the years, so there is bound to be some mechanicsl faiures. Could Honds have used a different/better transmission? Thats another debate for sure.
Also the jerking came back after a while, as per tech the solution was to keep resetting it once the symptoms re-appear.
I sold of the TLX in one year, this wasn't the only reason but it played a big part in that decision.
Possible solution:
Honda Pilot from 2016 and up has the same engine as the MDX, except slightly de-tuned for regular gas. Except for the highest trim levels, the trusty 6 speed transmission is standard. Fewer gears = fewer problems.
The new Honda Passport only comes with the 9 speed, so it's off my list as a possible replacement fro my MDX when the time comes.
Also note that transmission fluid change on the 9 speed runs in the $300-400 range and requires the factory scan tool to do properly. The six speed is a $35 DIY job that takes 10 minutes with regular tools.
The Kia/Hyunai twins actually offer much better value than the current MDX. The MDX only has its lineage and brand going in its favor at this time and value is only when compared to Germans but then again it doesn't offer as much features.
The 2018 would have been almost perfect with the older 6 speed
