Spare Wheel/Tire for 20" Wheels?
I've asked this question once before but didn't get any answers...long story short is I have OEM 20" wheels on my MDX and have a 17" spare tire. The spare tire size is 165/80D17. I've always been under the impression that using a different sized wheel will mess up the transmission. My question is is there a spare tire that is designed for the OEM 20" wheel options?
I've found 06421-TZ5-A51which says it is a 20" spare tire kit, but after calling a few dealerships, they say that it's actually a 17" spare wheel. Out of the three dealerships I've called, two are saying that the 17" spare tire that I have is all that is made for the MDX and that since I should only be driving on it for a small amount of time no damage should occur. Also, I could get a full sized spare, but it likely won't fit in the spare tire compartment. I just want to make sure I'm not setting myself up for larger issues but using the 17" spare tire with three 20" wheels.
But it's a spare, not intended to be used for a long period of time.
mrgold35
I did the same as ShortKarateGI for my MDX sport hybrid. The sport hybrid doesn't come with a spare tire, no tools to change a flat, or crank/cable to mount under the MDX. Found a black 20" Berlina rim and slightly used OEM Conti tire on eBay. I haven't mounted the spare yet because I just got everything in; but, had to go out of town for 2 weeks (took my 11 MDX with full size spare). I can be +500 miles from home and the speed limit is between 70-80 mph on the interstate hwys. Recommended of 70 miles max range at 50 mph max speed for a donut wouldn't work for me in the southwest.
mrgold35
I just added a full size spare to my 19 sh-sh-awd. I had the dealership install the spare tire kit minus the donut spare at purchase. I purchased the 20" Berlina rim ($210) and Conti CrossContact tire ($80) on eBay. I wrapped the spare in the bag Discount Tires used after they mount and balanced. Purchased an universal spare tire cover on Amazon, $15, to cover the tire to hide and keep cleaner under the MDX. Combo worked extremely well for my 11 MDX with a full size spare for the last +5 years.
Amazon spare tire cover:
37tzee (07-30-2019)
New member and owner of a 2019 Sport Hybrid Tech here. To summarize this discussion, you all recommend getting the spare tire kit minus the donut spare and then get a tire elsewhere? Is the kit available online for a DIY? Anyone knows what are the parts needed for that?
Much appreciate all the helpful responses!
08 NBP TL
09-27-2010 06:38 PM
sidemarker
2G CL Transmission Recall Q & A
19
01-27-2004 02:57 PM
