Should a new 2018 MDX already leak oil?
I recently purchased a 2018 MDX (not AWD) and it has 1800 miles. I noticed this weekend a little oil on the garage floor -- just a few drops. Is that normal?
I purchased the car back in September and the temperatures recently dropped to the upper 30's so I didn't know if the seals haven't set yet.
Thanks,
Tomer
Thanks,
Tomer
Cajun Gumbo Man
You should have NO leaks.....
Make sure to check all the TSB listed here for leaking part near transmission (ZF9) in particular.... bring those with you to dealership.... Good luck!
Tomer Tishgarten (12-03-2018)
An amateur oil change can provide leaks as well, or at least the perception of leaks. You know, the one where you try to pour out of the bottle into the oil reservoir without a funnel? Missing the opening for the first couple of ounces. It happens and the oil ends up on the motor and anywhere else eventually making it to the ground.
Do you smell oil burning as well? Newer vehicles should be immune to this issue. Get it back to the dealer. Good luck!
Thanks everyone for jumping in. Dealer had to keep it for a few days to find the issue: leaking oil from corner of oil pan assembly. Looks like they took the oil pan and found a spot on the pan that had no sealant. They resealed the oil pan with new Hondabond sealant.
