Passsenger RH Axle replacement
I need to replace my passenger Axle Assembly with OEM on my 2014 MDX FWD and it seems all the online vendors have it listed as discontinued. The listed part # is 44305-TZ5-A01 I see that some websites lists 44305 TZ5 A11 as 'another name" but when I select that, it shows that it's not compatible with the 2014 FWD. Even the AWD ones are showing as discontinued.
Does anyone know if the 44305-TZ5-A11 will work on the 2014 FWD MDX?
TIA.
TIA.
Not sure if you sorted this out but here is a link to the honda parts web site that shows the part number. You may want to put your vin number in to make sure the trim level is correct.
https://dreamshop.honda.com/s/catego...g0000004HomGAE
