MDX CarPlay
MDX CarPlay
Hi,
Hoping someone can help.
I have a base model 2019 MDX. I am trying to start up the CarPlay on it. The tech screen simply says initiating and is stuck, the CarPlay is not highlighted.
I have the phone plugged into the car with the smartphone usb port.
The Bluetooth does work to make calls.
Am I missing anything to start CarPlay? Do I need to restore the factory settings?
thabk you
thabk you
Hi,
thabk you
thabk you
One day, while I had the error, I took it to the dealer and only then, they agreed to change the whole infotainment computer. My theory always was that the car USB port was the culprit but they wouldn’t change it.
After the computer swap, Car Play improved dramatically and had a successful connect rate north of 90%. Just a a couple of days ago, it started miss behaving again and refusing to connect. The only fix is restarting the engine…
The issue happens with my wife’s iphone as well and tried multiple original apple cables.
autoperformance
3G MDX (2014-2020)
Sep 14, 2019 06:56 PM
drdomore
3G MDX (2014-2020)
Feb 3, 2015 12:02 AM
