instrument cluster lens replacement
I'm in the process of purchasing a used 2018 MDX nav, and there's unfortunately a slight crack in the instrument gauge cluster lens.
I'm told that it's a 8-10 hour job to replace.
I think they're trying to pull the wool over my eyes.
are there instructions somewhere to replace the lens? second, where could I find the part number?
thank you for any help,
D
D
Sounds about right. You need to pull the dash apart to get at it I suspect. Once apart a new piece of Plexiglas should be cheap and easy to find.
now if this is a CPO the dealer should fix it before delivery to you.
BoomWish (06-04-2022)
Here is a link from another forum https://www.mdxers.org/threads/2015-...4/post-1470780
https://www.mdxers.org/threads/instr.../#post-1511114
I actually replaced it on my own, I still couldn't figure out how was it got cracked..anyway, it's not hard, just gently pry off the parts, don't use force.
moose66 (06-13-2022)
Check out this link for part
https://www.curryacuraparts.com/oem-...Y2LWdhcw%3D%3D
