Idle-stop feature
Anyone has any feedback on the MDX's Idle-stop feature? It comes with the Advance Package (or Elite in Canada). Is it an annoying feature?
My friend owns a Mercedes with that feature. I have ridden in it. I think its annoying and my friend hates it. They have to use a super duty starter, because the starter has to work every time after a stop. On the Mercedes, he can push a button on the dash to turn the feature off. He rather defeat that feature 100% of the time, but he can only do it while the car is running. Be nice if Acura will allow you to turn it off 100% of the time, like turning off Lane departure with a button. Something to ask when visiting the dealer. I have no idea what option is available if you want it off.
If it's like the TLX, I don't mind the implementation. There's a button to disable it, but it only works for the duration of the drive and will default back to On (probably for EPA reasons). However, after a bit of time I've gotten familiar with the amount of pressure on the brake needed to stop the car but not cause the idle stop to activate. Sports+ mode also disables it, but since the MDX doesn't have that mode, I'm not sure if any of its other IDS modes can disable it.
The start operation is pretty quick; the engine automatically starts after lifting off the brake pedal and by the time my foot is on the accelerator the engine is ready to go. In spring-like conditions, it can run on the battery for a couple of minutes so it's useful when I get to a stop that I know will take some time to turn green. The one poor aspect is that when idle stop occurs when parking and I go select Park but it strangely starts the engine again. It logically shouldn't do that, since the engine is going to be shut off shortly anyways. |
Originally Posted by kareshi
(Post 15378465)
It can be disabled by pressing a button on the centre console. |
Please change name on th
It gets better. If you don't want to use auto/start stop, don't push too hard on the brake pedal when stopped. The engine will keep running. If you change your mind, push harder on the brake pedal and the engine will stop. Brilliant.
Acura implemented it very well, and unlike many of the German systems, it's smooth enough many people don't even realize it happened.
I would prefer if you could shut this feature off rather than have to do it each time you start the car.
Originally Posted by Pens Fan
(Post 15383946)
This is a cool feature to experiment. Like said above it won't activate until you hard press the brake.
But the question I have is how can can it save fuel ? I thought stopping/starting will burn more fuel or not good for the car. |
Originally Posted by mdxrebel
(Post 15385284)
But the question I have is how can can it save fuel ? I thought stopping/starting will burn more fuel or not good for the car. http://www.afdc.energy.gov/uploads/p...is_greener.pdf |
