How do I clear error message after repairing flat tire on 17 MDX?
I have the 2017 MDX and got a flat tire. I repaired the tire but the TPMS system still has an error message.
How I clear the error message now that the tire is repaired?
Please advise. Thanks.
Something may have been damaged. How long did you drive on the flat tire? The sensor in the wheel itself may have been damaged.
The TPMS sensors in the wheels will reset themselves with the car after remounted and if the tire has adequate air pressure. Go to the info display and look at the tire pressure readings. Is the tire that you repaired showing a value? If not then the sensor might be not working and has to be replaced.... The MDX (and other Acuras that show the actual PSI reading on each tire) does an auto-detect after you drive the car for a mile or so. I see this all the time when I swap to winter wheels/tires where the sensors need to reset....
andy
andy
