help locating fuse for radio 16 MDX
Old 10-16-2017, 01:17 PM
5th Gear
whar's Avatar
I must have blown the fuse for my radio. They are now blank (both screens). Everything else works fine. I've checked manual and googled all over and couldn't find out which fuse I should check. I figured I might get some help here before I check all the fuses one by one (ouch!)
Any help would be greatly appreciated. Thanks so much.
Old 10-17-2017, 09:24 PM
moose66's Avatar
Everything else works? So you are saying the music still plays, etc. Have you disconnected and reconnected the battery?
Old 10-17-2017, 10:03 PM
5th Gear
whar's Avatar
Music is not playing... no radio, nothing from the speaker. but the HVAC control is working. .
I checked ALL the fuse. they seems fine. I am out of ideas. Maybe heading to the dealership?
Old 10-17-2017, 10:32 PM
Received 8,711 Likes on 6,718 Posts
Did you use a continuity meter to check the fuse or did you just look at them
Old 10-17-2017, 10:56 PM
5th Gear
whar's Avatar
I just looked at them. Didn't check continuity. Shall I check it?
Old 10-17-2017, 11:01 PM
5th Gear
whar's Avatar
I've never saw bad fuse without blown. Is that possible?
Old 10-18-2017, 03:26 PM
5th Gear
whar's Avatar
Found it. #15 20A in main fuse box in engine compartment. I totally missed this fuse box initially.
