Dashboard warning lights
Hello all,I have a 2017 Acura MDX with the following warning lights onHigh beam support system problemLane keeping assist problemCollision mitigation system problemRoad departure mitigation system problemAdaptive cruise control problemThe problem just started,I recently bought a new battery within a year and I checked the voltage. It's 12.7 off and 14.3 on. Terminals are cleaned and tight.No codes are coming up when I run a engine diagnostic.Any ideas?
Hello I just noticed a technical service bulletin.
TSB 23-008 - LKAS, ACC, or CMBS Indicators On with DTC U3000-49Applies To: 2017-18 MDX - ALL2017-18 MDX Sport Hybrid - ALL
Do you think this is causing my issues?
I don't have any check engine light codes when I connect my obd scanner.
Also does anybody know how much it would cost for Acura to apply this?
Tatewaki
Mar 28, 2004 05:08 PM
