Changing out the wheels my hybrid to Advance 20 x 8 1/2" wheels.
I just purchased a set of take-off wheels from Acura dealer on Ebay for a set of 20 x 8 1/2" Advanced wheels to replace the stock 20 x 8" that the MDX came with. I'm assuming I not going to have any issues with the increased width on a Hybrid.
mrgold35
Post some pics once you get them on. Are you going to re-use the OEM Conti tires or upgrade those also.
mrgold35
I have the Conti DWS 06 on my 11 MDX, 08 RDX, and 11 TSX right now. Thinking about upgrading to Aspec or aftermarket 20X8.5 rims to do the Conti DWS 06 tires down the road on my hybrid.
Does half inch make that much of a difference in the looks?
Will be 5 mm (0.2'') closer to suspension/brakes components. Acceptable for most cars.
will stick out 15 mm (0.6'') farther. Acceptable for most cars.
Also, when speedometer reads 60mph (96.6km/h) actual speed will be 59.4mph (95.6km/h): 1% slower.
Personally, i'd buy non OEM wheel when sizing up as OEM wheels are known to be heavy. Last thing you want is an increase in unsprung weight on your nice already handling MDX. So, rather than increasing the tire width, you should play with wheel offset and try to fill out the fender a little better. You should also think about the mpg penalty of using larger tires...
Just my two cents........
I think the Tech & Hybrid Wheels are 20x8 with a 55mm offset. The ASpec and Advance Wheels are 20x8.5 with a 50mm offset. I just purchased ASpec Wheels to put on my Tech but I’m going with a 275/45/20 tire vs the stock 245/50/20 stock tire. I think the extra 1.2 inches in with plus extra 5mm offset toward the fender will fill in nicely. We’ll see in a few weeks.
Compared to the OEM tire/wheel combo these packages -
Please do those wheels justice and wrap them in 275's!!! I would even do a 40 series side wall
Looking ate the size difference between the 265/45R20 and 275/45R20
The tires on the left is the 265/45R20 and to the right in the the 275/45R20.
265/45R20
275/45R20
bmoua15 (09-14-2019)
I have these Advance wheels on my 19 Tech but used the existing 245 tires since the tires were brand new. While it does make the appearance a “little” bit difference since it’s on a half inch wider rim I would like to see these 275s on them. Which Michelin series were you thinking of going with?
https://www.tirerack.com/tires/tires...omCompare1=yes
TLJVN
04-01-2015 09:50 AM
bigBLACKTL
10-23-2008 11:53 PM
