can engine be turned off when driving?
Here is from Acura MDX owner's manual:
"If the power mode is set to ACCESSORY or VEHICLE
OFF (LOCK) while driving, the engine will shut down
and all steering and brake power assist functions will
stop, making it difficult to control the vehicle."
isn't that dangerous? what is the use to allow turning off engine while driving?
try to access the risk of accidently stop engine during driving before I buy MDX. how to change power mode in MDX during driving? I couldn't find it in MDX owner's manual.
I find below in Toyota Highlander's owner's manual:
"If you want to stop the engine in an emergency while driving the vehicle,
press and hold the engine switch for more than 2 seconds, or press it briefly
3 times or more in succession. "
also from some threads/web, i see couple of losing control/accelaration/steering/braking complaints, just wondering if accidently push start button or some sort of electrical failure from this function increases the driver's risk.
Emergency Engine Stop
The ENGINE START/STOP button may be used to stop the engine due to an
emergency situation even while driving. If you must stop the engine, do either of the
following operations:
• Press and hold the ENGINE START/STOP button for about two seconds.
• Firmly press the ENGINE START/STOP button two times.
• The steering wheel will not lock. The power mode changes to VEHICLE OFF with
the shift lever in (P, and to ACCESSORY with the shift lever in any position other
than (P.
• Because turning off the engine also disables the power assist the engine provides
to the steering and braking systems, it will require significantly more physical
effort and time to steer and slow the vehicle. Downshift gears and use both feet
on the brake pedal, if necessary, to slow the vehicle and stop immediately in a
safe place.
NOTICE
Do not press the button while driving unless it is
absolutely necessary for the engine to be switched
off.
That is no different than turning off the ignition key while driving, with all other conventional ignition key start vehicles.
Stay Out Of the Left Lane
for conventional ignition key start vehicles, do you have to depress brake pedal when shift is in "D" to turn off engine? thanks.
p.459 for 2014 MDX:
than (P.
safe place.
NOTICE
off.
than (P.
safe place.
NOTICE
off.
in conventional key system, once turning off engine in "D" mode, owner still has to change to shift "P" to remove the key. so it is not likely car stay in "D" mode after owner left.
but in keyless system, owner will have chance to walk away with remote while engine shut off in shift "D" mode. this is not safe and car might still roll forward.
HeloDown
Sep 8, 2015 06:51 PM
