Auto Climate Control Stopped Working
I have a 2015 MDX and the auto climate control has stopped working. When I press the button, it will not come on. It appears I can run the a/c or heater without auto. This started 2 weeks ago and has me baffled. Any ideas?
define won't come on. Mine for example if it is set to say 70 F and it is 65 F outside just blows air. The same system when it is 80 F outside will blow cold air. Try running the temperature up or down to the max setting and see if that changes things. It is a pretty confusing system. In auto, the fan speed I set is what blows all the time except in the max settings for cold or hot. So maybe your fan speed is set to off or 1.
ericle613
08-29-2006 03:46 PM
FlyingPig
03-31-2001 12:35 AM
