2019 Advanced in Sport mode
We’re thinking of buying a 2109 MDX Advanced. I have a 2012 MDX Tech. I’ve been pretty happy with it with one exception. In sport mode the transmission won’t stay in first gear. I do a lot of fishing and have to work down some fairly step grades on gravel roads. I’d like to use engine breaking. I start out in first gear but almost immediately it shifts to second and I have to ride the breaks all the way down.
My my question is does the 2019 8 speed transmission behave that way or will it stay in 1st gear? Thanks! |
I recently diwcovered that mym2018 when in Sport mode the paddle shifters work. I was led to believe thwt they only worked when manual mode was selected? Hummm.
Yes you can only start in 1st gear in Sport mode (manual with paddles) otherwise the car starts in 2nd. This is also know as "Ludicrous mode" on our MDX Sport Hybrids 😃
Will it stay in first gear or automatically shift to second at some rpm?
Originally Posted by Donn0128
(Post 16411194)
I recently discovered that my 2018 when in Sport mode the paddle shifters work. I was led to believe that they only worked when manual mode was selected? Hummm.
D/S in D Dynamic in S allows you to use the paddles to shift. It will remain in selected gear until you tap the + paddle. Not what I was led to believe, but oh well. |
(Post 16411231)
Since the forum wont allow me to edit my post, so........
D/S in D Dynamic in S allows you to use the paddles to shift. It will remain in selected gear until you tap the + paddle. Not what I was led to believe, but oh well. Does the MDX have rev matching auto downshifts while in full auto mode or sequential mode (provided you haven't manually shifted gears so no gear number is indicated in the MID)? Or does it do anything with this in IDS Sport mode? It didn't seem like as I was slowing down that it was downshifting to help with deceleration due to engine braking but wasn't sure if this was dependent on how aggressive you are driving at the moment or if it just doesn't do this at all. |
Thanks for all the replies. However, I still don’t think my question has been answered. When I start driving my 2012 Tech with the paddles it starts in First gear and quickly shifts to second without any input from me. If I’m in second gear and paddle downshift to first as soon as it hits around 3000 rpm it automatically shifts into second. It will not stay locked in first gear under any circumstances.
So again, does the 2019 exhibit the same behavior? Thanks! |
Originally Posted by GBeeman
(Post 16412324)
ok - I have the hybrid
I put it in Sequential and Sport+ dynamic mode It would not stay in 1st. It shifted very quickly right around 3K rpm, maybe a touch before Wonder how much engine braking you would get in 2nd |
On my 2018 Advance, in S mode it will hold 1 all the way to redline if you let it. Very useful on some rocky tracks in death valley last Christmas :)
how - I hit paddles to downshift into 1 and it almost immediately shifted to 2
The regular SHAWD 9 speeds in Sequential shift mode will hold gears till redline by design until you use the paddle shifters to upshift or you redline.
Originally Posted by undertaker2k8
(Post 16413248)
(Post 16411112)
My my question is does the 2019 8 speed transmission behave that way or will it stay in 1st gear? Thanks! I have a 2010 Acura MDX and I know exactly what your talking about, it upshifts to 2nd gear whenever you get about 8-10 mph, and you can't keep it locked in 1st gear. It appears from the owner's manual for the 2018 on page 481 that it does the same thing, automatically shifts at redline whether it's in normal drive mode or sequential. http://techinfo.honda.com/rjanisis/p...BTZ51919OM.PDF https://cimg2.ibsrv.net/gimg/acurazi...cd249800aa.jpg |
OP, while the 9 speed will hold gears until redline in sequential, 1st gear is very short. So depending on how fast you go down the path, it will shift up to 2nd in no time. Trying to keep first under redline is very time consuming.
The 2007 MDX would allow you to hold it in first gear....either 08 or 09 they changed it to where it will quickly shift to 2nd gear... Apparently too many socker moms in manual mode were blowing up their transmissions..... Lots of complaints about this back then....
Originally Posted by Fabvsix
(Post 16413343)
Thanks all!
Originally Posted by ddswv
(Post 16413751)
It's too bad Acura never implemented a "Downhill Assist" that would be beneficial.
