Originally Posted by lsulaker
(Post 16223196)
Im almost positive the batteries are warrantied for 8.5 years or 100,000 miles, whichever comes first.
The Hybrid system has a lot of components with longer warranty. It's located on the last page of my warranty book... ( I tried a cut and paste below but it all ran together, just check your warranty book).
Federal and California Emissions Warranties Parts List BPL04916 (1701) 00X31-TRX-W000 2017 MDX Sport Hybrid Emissions warranties are state specific. Refer to the years/miles1 columns below as follows: • A – Minimum coverage for all vehicles in all states • B – Vehicles registered and normally operated in California, Connecticut, Delaware, Maine, Maryland, Massachusetts, New Jersey, New York, Oregon, Pennsylvania, Rhode Island, Vermont, and Washington System Covered/Part Name A B Evaporative and Refueling Emissions Control System Fuel Tank (including Fuel Tank Vapor Control Valve and Vapor Recirculation Tube) 4/50 7/70 Fuel Pressure Regulator 4/50 7/70 Fuel Filter2 4/50 7/70 Fuel Filler Neck Restrictor 4/50 7/70 Exhaust System Catalytic Converters 8/80 8/80 Fuel Injection System Engine/Powertrain Control Module (including Barometric Pressure Sensor and Software Upgrades) 8/80 8/80 Fuel Rails 4/50 7/70 OBD System Data Link Connector (DLC) 4/50 7/70 Malfunction Indicator Lamp (MIL) 4/50 7/70 Transmission Control System Transmission Control Module (including software upgrades) 8/80 8/80 Actuator Assembly 4/50 7/70 System Covered/Part Name A B Intake Air System Intake Manifold Assembly 4/50 7/70 Valve Control System Rocker Arm Control Valve Assembly 4/50 7/70 Hybrid System Battery Assembly (including all internal components) 8/100 8/100 Motor Control Module (including software upgrades) 8/100 8/100 Motor Power Inverter Module (including all internal components) 8/100 8/100 Motor Rotor 8/100 8/100 Motor Stator 8/100 8/100 Electric Motor Control Module Coolant Pump Relay 4/50 7/70 Motor Control Module Relay 4/50 7/70 Battery Module Fuse 4/50 7/70 Battery Module Fan Relay 4/50 7/70 Bypass Contactor and Resistor 4/50 7/70 Battery Condition Monitor Module 4/50 7/70 High Voltage Contactor 4/50 7/70 Motor Power Cable 4/50 7/70 Federal and California Emissions Warranties Parts List BPL04916 (1701) 00X31-TRX-W000 2017 MDX Sport Hybrid System Covered/Part Name A B Hybrid System (cont.) High Voltage Motor Power Inverter Module Cable 4/50 7/70 Hybrid System Relays 4/50 7/70 Miscellaneous Parts that are used in conjunction with the items in this list are covered. Some examples are clamps, brackets, piping, nuts, bolts, fasteners, switches, sensors, solenoids, wires, harnesses, connectors, seals, software updates, and gaskets. 1 Coverage in years or 1,000 miles, whichever comes first. 2 Fuel filter replacement and fuel tank flushing are covered when contamination results from a defect in material or workmanship. |
Anyone out there with a 2018 Sport Hybrid, experience weird noises coming from the back when the electric motors kick in? Mine make a buzzing sound from time to time when I’m accelerating away at light to medium throttle, a similar sound to a loose heatshield buzzing . As well, when it’s cooler outside, I get a droning sound from the front end which I believe is the electric motor, which largely goes away as the car warms up. Thanks. |
Originally Posted by SMMN
(Post 16294048)
Anyone out there with a 2018 Sport Hybrid, experience weird noises coming from the back when the electric motors kick in? Mine make a buzzing sound from time to time when I’m accelerating away at light to medium throttle, a similar sound to a loose heat shield buzzing . As well, when it’s cooler outside, I get a droning sound from the front end which I believe is the electric motor, which largely goes away as the car warms up. Thanks. |
