2017 Acura MDX Technical Service Bulletins
Forum Contributor
Received 1,392 Likes
2017 Acura MDX Technical Service Bulletins:
TSB 16-026 - 2017 MDX: TQI and New Model Service Information
Applies To: 2017 MDX - 2WD
2017 MDX - 2WD with Technology Package
2017 MDX - 2WD with Technology and Entertainment Packages
2017 MDX - 2WD with Advance Package
2017 MDX - 2WD with Advance and Entertainment Packages
2017 MDX - SH-AWD
2017 MDX - SH-AWD with Technology Package
2017 MDX - SH-AWD with Technology and Entertainment Packages
2017 MDX - SH-AWD with Advance Package
2017 MDX - SH-AWD with Advance and Entertainment Packages
http://www.urvi.net/forumfiles/SB/B16-026.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16-026.PDF
TSB 16-027 - 2017 MDX: TQI of the Navigation System
Applies To: 2017 MDX - All with Navigation
http://www.urvi.net/forumfiles/SB/B16-027.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-027.PDF
TSB 17-013 - 2017 MDX Sport Hybrid: TQI and New Model Service Information
Applies To: 2017 MDX Sport Hybrid - With Technology Package, With Advance Package
http://www.urvi.net/forumfiles/SB/B17-013.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-013.PDF
TSB 17-014 - 2017 MDX Sport Hybrid: TQI of the Navigation System
http://www.urvi.net/forumfiles/SB/B17-014.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-014.PDF
TSB 14-025 - Timing Belt Chirps
Applies To: 2014-18 MDX - ALL - ALL
2019 MDX - 2WD - From VIN 5J8YD3...KL000001 thru 5J8YD3...KL005096
2019 MDX - AWD - From VIN 5J8YD4...KL000001 thru 5J8YD4...KL011104
2019 MDX Sport Hybrid - From VIN 5J8YD7...KL000001 thru 5J8YD7...KL000483
http://www.urvi.net/forumfiles/SB/B14-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-025.PDF
TSB 15-039 - Transmission End Cover Leaks (9-Speed A/T)
Applies To: 2016-17 MDX - ALL with 9-speed A/T - ALL
http://www.urvi.net/forumfiles/SB/B15-039.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-039.PDF
TSB 16-008 - High Pressure Fuel Pump Chirps
Applies To: 2014-17 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B16-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-008.PDF
TSB 16-031 - Power Tailgate Won’t Open from the Outside in Cold Weather
Applies To: 2015 MDX - ALL - ALL
2016 MDX - ALL - ALL
2017 MDX - 2WD - From VIN 5FRYD3H..HB000001 to 5FRYD3H..HB006289
2017 MDX - SH-AWD - From VIN 5FRYD4H..HB000001 to 5FRYD4H..HB018917
2017 MDX SPORT HYBRID - ALL - From VIN 5FRYD7H..HB000001 to 5FRYD7H..HB000041
http://www.urvi.net/forumfiles/SB/B16-031.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-031.PDF
TSB 17-008 - Buttons Sticking on Center Switch Panel/Interface Dial (Day/Night, SETTINGS, NAV, AUDIO, or others)
Applies To: 2014–17 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B17-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-008.PDF
TSB 17-010 - Product Update: MDX 9-Speed Transmission Warmer (Transmission Previously Replaced for Transmission Warmer Leaking)
Applies To: 2016 MDX - All - Check the iN VIN status for eligibility
2017 MDX - All - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B17-010.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-010.PDF
TSB 17-020 - Product Update: MDX Accessory Temporary Spare Tire Kit
Applies To: 2017 MDX - ALL 2WD except hybrid - Check the iN VIN status eligibility
http://www.urvi.net/forumfiles/SB/B17-020.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-020.PDF
TSB 17-026 - Warranty Extension: MDX Transmission Chirps During 3-4 Shift, Poor Shift Quality, or Engine Overheats Because of Defective ATF Warmer
Applies To: 2016 MDX - ALL - Check the iN VIN status for eligibility
2017 MDX - ALL - Check the iN VIN status for eligibility (Five MDXs affected)
http://www.urvi.net/forumfiles/SB/B17-026.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-026.PDF
TSB 17-029 - Safety Recall: 2017 MDX Hybrid Fuel Feed and Purge Hose Mis-Installation
Applies To: 2017 MDX Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B17-029.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-029.PDF
TSB 17-034 - MIL Comes On with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank 2])
Applies To: 2014-16 MDX (except Sport Hybrid) - ALL - ALL
2017 MDX (except Sport Hybrid) - 2WD - From VIN 5FRYD3...HB000001 - 5FRYD3...HB014264 and 5J8YD3...HL000001 - 5J8YD3...HL000229
2017 MDX (except Sport Hybrid) - SH-AWD - From VIN 5FRYD4...HB000001 - 5FRYD4...HB040999 and 5J8YD4...HL000001 - 5J8YD4...HL000507
http://www.urvi.net/forumfiles/SB/B17-034.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-034.PDF
TSB 18-004 - Flickering Lights, Multiple Indicators Coming On, Jerky Steering and/or Voltage-Related Fluctuations
Applies To: 2017 MDX - ALL - From VIN 5FRYD....HB002036 to 5FRYD....HB025970
http://www.urvi.net/forumfiles/SB/B18-004.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-004.PDF
TSB 18-007 - Shutter Set for Capless Fuel Filler (Mis-Fuel Inhibit Device) Is Frozen
Applies To: 2017 MDX - ALL - ALL
2018 MDX - ALL except Sport Hybrid - ALL
http://www.urvi.net/forumfiles/SB/B18-007.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-007.PDF
TSB 18-011 - GPS Shows Vehicle in the Wrong Location
Applies To: 2017 MDX - All with navigation - ALL
http://www.urvi.net/forumfiles/SB/B18-011.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-011.PDF
TSB 18-014 - Clicking from the Power Seat While Using the Height or Tilt Adjustment
2017-18 MDX Sport Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B18-014.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-014.PDF
TSB 18-030 - Product Update: 2017 MDX Sport Hybrid Owner Information CD
Applies To: 2017 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B18-030.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-030.PDF
TSB 18-061 - Safety Recall: Soft or Low Brake Pedal
Applies To: 2017-19 MDX - ALL - Check the iN VIN status for eligibility
2017-18 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B18-061.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-061.PDF
TSB 18-073 - Fuel Fill Door Rear Edge Does Not Line Up
Applies To: 2017-19 MDX - ALL - VINs that start with 5J8YD
2017-19 - MDX Sport Hybrid - ALL - VINs that start with 5J8YD
http://www.urvi.net/forumfiles/SB/B18-073.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-073.PDF
TSB 19-003 - MIL Comes On with DTC P0716
Applies To: 2016-17 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-003.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-003.PDF
TSB 19-004 - 2014-19 RLX Sport Hybrid and 2017-19 MDX Sport Hybrid: Transmission Judders, Shudders, or Surges While Driving
Applies To: 2017-19 MDX Sport Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-004.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-004.PDF
TSB 19-005 - Multiple Indicators On and Option Fuse (E21 or B7) Blown
Applies To: 2016-19 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-005.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-005.PDF
TSB 19-011 - Safety Recall: 2016-18 MDX and 2015-19 TLX V6 Fuel Pump
Applies To: 2016-18 MDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-011.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-011.PDF
TSB 19-017 - Buzzing or Whining When Adjusting Front Seat Forward and Backward
Applies To: 2014-19 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-017.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-017.PDF
TSB 19-019 - Safety Recall: 2014-19 MDX Inner Lights
Applies To: 2014-19 MDX - ALL - Check the iN VIN status for eligibility
2017-19 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-019.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-019.PDF
TSB 19-027 - Service Manual Update: 2014-19 MDX and 2017-19 MDX Sport Hybrid Inner Taillight Sub Harness
http://www.urvi.net/forumfiles/SB/B19-027.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-027.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2005-20 MDX
2017-20 MDX Sport Hybrid
http://www.urvi.net/forumfiles/SB/B19-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF
TSB 20-015 - 9-Speed A/T Hard Upshift with Steady Acceleration
2020 MDX - AWD - From VIN 5J8YD4...LL000001 thru 5J8YD4...LL011456
2020 MDX - 2WD - From VIN 5J8YD3...LL000001 thru 5J8YD3...LL003798
http://www.urvi.net/forumfiles/SB/B20-015.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-015.PDF
TSB 20-018 - MIL Comes On with DTC P061B
Applies To: 2017-18 MDX Sport Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B20-018.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-018.PDF
TSB 20-022 - Service Manual Update: Second-Row Seat Frame Replacement
Applies To: 2014-20 MDX
http://www.urvi.net/forumfiles/SB/B20-022.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-022.PDF
TSB 20-039 - Emissions Recall: 2017-20 MDX Sport Hybrid Odd Gear Monitor Software Update
Applies To: 2017-20 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B20-039.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-039.PDF
TSB 23-001 - Product Update: 2016-23 MDX PGM-FI Idle Stop Software Update
Applies To: 2016-20 MDX - All (except Hybrid) - Check the iN VIN status for eligibility
2022-23 MDX - All (except Hybrid & Type S) - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B23-001.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-001.PDF
TSB 23-002 - Warranty Extension: Engine Does Not Auto Restart After Entering Auto Idle Stop
Applies To: 2016-20 MDX (with 9A/T) - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B23-002.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-002.PDF
TSB 23-008 - LKAS, ACC, or CMBS Indicators On with DTC U3000-49
Applies To: 2017-18 MDX - ALL
http://www.urvi.net/forumfiles/SB/B23-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-008.PDF
TSB 23-009 - Engine Does Not Crank
Applies To: 2016-20 MDX - ALL (except Hybrid) - ALL
http://www.urvi.net/forumfiles/SB/B23-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-009.PDF
TSB 23-036 - Safety Recall: 2015-20 Multi-Model Connecting Rod Bearing Stop Sale
Applies To: 2016-20 MDX - ALL (except Hybrid) - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B23-036.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-036.PDF
TSB 24-001 - Safety Recall: 2016–20 MDX Connecting Rod Bearing
Applies To: 2016-20 MDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-001.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-001.PDF
TSB 24-006 - Safety Recall: 2014–20 MDX and 2018–20 MDX Sport Hybrid Fuel Pump Motor
Applies To: 2014-20 MDX - ALL - Check the iN VIN status for eligibility
2018-20 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-006.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-006.PDF
http://techinfo.honda.com/rjanisis/p...B24-006 v2.PDF (Link works, but is wrong) Version 2
2017 MDX - SH-AWD
Gadgetjq (11-28-2016)
