2016 Acura MDX Technical Service Bulletins
Forum Contributor
Received 1,392 Likes
2016 Acura MDX Technical Service Bulletins:
TSB 15-004 - 2016 MDX: TQI and New Model Service Information
Applies To: 2016 MDX - All
http://www.urvi.net/forumfiles/SB/B15-004.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-004.PDF
TSB 15-005 - 2016 MDX: TQI of the Navigation System
Applies To: 2016 MDX - All with Navigation
http://www.urvi.net/forumfiles/SB/B15-005.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-005.PDF
TSB 14-025 - Timing Belt Chirps
Applies To: 2014-18 MDX - ALL - ALL
2019 MDX - 2WD - From VIN 5J8YD3...KL000001 thru 5J8YD3...KL005096
2019 MDX - AWD - From VIN 5J8YD4...KL000001 thru 5J8YD4...KL011104
2019 MDX Sport Hybrid - From VIN 5J8YD7...KL000001 thru 5J8YD7...KL000483
http://www.urvi.net/forumfiles/SB/B14-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-025.PDF
TSB 14-031 - Steering Column Screeches When Moving
MDX was removed from this bulletin. Refer to service bulletin 18-033, 2014-16 MDX: Steering Column Screeches When Moving.
TSB 15-023 - HomeLink System Has Weak or Limited Range
Applies To: 2014–16 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B15-023.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-023.PDF
TSB 15-027 - LKAS Does Not Keep Vehicle in Detected Lane
Applies To: 2016 MDX - Advance, All with AcuraWatch Plus - ALL
http://www.urvi.net/forumfiles/SB/B15-027.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-027.PDF
TSB 15-034 - Product Update: Vehicle Shifts into Neutral and MIL Comes On with DTC P0657
Applies To: 2016 MDX - With 9-speed A/T - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B15-034.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-034.PDF
TSB 15-039 - Transmission End Cover Leaks (9-Speed A/T)
Applies To: 2016-17 MDX - ALL with 9-speed A/T - ALL
http://www.urvi.net/forumfiles/SB/B15-039.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-039.PDF
TSB 15-046 - Security System Sounds or May Not Set
Applies To: 2014–15 MDX - ALL - ALL
2016 MDX - ALL 2WD - From VIN 5FRYD3H..GB000001 to 5FRYD3H..GB007326
2016 MDX - ALL SH-AWD - From VIN 5FRYD4H..GB000001 to 5FRYD4H..GB029373
http://www.urvi.net/forumfiles/SB/B15-046.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-046.PDF
TSB 15-053 - MIL Comes On with DTC P0430
This bulletin is replaced by S/B 17-034, MIL Comes On with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank 2])
http://www.urvi.net/forumfiles/SB/B15-053.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-053.PDF
TSB 15-054 - Transmission Function Improvements: Sensation of Surge While Braking, Slow Downshift Response at Low Engine Speeds and Other Listed Symptoms
Applies To: 2016 MDX - 2WD Base - From VIN 5FRYD3H2.GB000001 thru 5FRYD3H2.GB012656
2016 MDX - 2WD Technology - From VIN 5FRYD3H4.GB000001 thru 5FRYD3H4.GB012723
2016 MDX - 2WD Technology and Entertainment - From VIN 5FRYD3H6.GB000001 thru 5FRYD3H6.GB012711
2016 MDX - 2WD Advance - From VIN 5FRYD3H9.GB000001 thru 5FRYD3H9.GB012787
2016 MDX - AWD Base - From VIN 5FRYD4H2.GB000001 thru 5FRYD4H2.GB039814
2016 MDX - AWD Technology - From VIN 5FRYD4H4.GB000001 thru 5FRYD4H4.GB039727
2016 MDX - AWD Technology and Entertainment - From VIN 5FRYD4H6.GB000001 thru 5FRYD4H6.GB040204
2016 MDX - AWD Advance - From VIN 5FRYD4H9.GB000001 thru 5FRYD4H9.GB039756
http://www.urvi.net/forumfiles/SB/B15-054.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-054.PDF
TSB 16-008 - High Pressure Fuel Pump Chirps
Applies To: 2014-17 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B16-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-008.PDF
TSB 16-031 - Power Tailgate Won’t Open from the Outside in Cold Weather
Applies To: 2015 MDX - ALL - ALL
2016 MDX - ALL - ALL
2017 MDX - 2WD - From VIN 5FRYD3H..HB000001 to 5FRYD3H..HB006289
2017 MDX - SH-AWD - From VIN 5FRYD4H..HB000001 to 5FRYD4H..HB018917
2017 MDX SPORT HYBRID - ALL - From VIN 5FRYD7H..HB000001 to 5FRYD7H..HB000041
http://www.urvi.net/forumfiles/SB/B16-031.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-031.PDF
TSB 16-032 - Safety Recall: 2015–16 MDX Fuel Tank
Applies To: 2015-16 MDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B16-032.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-032.PDF
TSB 16-035 - Rattle or Clunk from the Rear Suspension
Applies To: 2014-16 MDX - ALL with 2WD - ALL
2014-16 MDX - ALL with 4WD - ALL
http://www.urvi.net/forumfiles/SB/B16-035.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-035.PDF
TSB 16-042 - Squeak and/or Pop from the Front Suspension While Turning
2014-16 MDX - ALL with SH-AWD - ALL
http://www.urvi.net/forumfiles/SB/B16-042.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-042.PDF
TSB 16-048 - Audio-Navigation System Update for Upper Screen Going Blank
Applies To: 2016 MDX - 2WD Tech, Tech-Ent, ADV, ADV-Ent - From VIN 5FRYD3...GB000000 thru 5FRYD3...GB011547
2016 MDX - AWD Tech, Tech-Ent, ADV, ADV-Ent - From VIN 5FRYD4...GB000000 thru 5FRYD4...GB037480
http://www.urvi.net/forumfiles/SB/B16-048.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-048.PDF
TSB 16-056 - Power Tailgate Does Not Work
Applies To: 2014-15 MDX - ALL - ALL
2016 MDX - 2WD - From VIN 5FRYD3...GB000001 thru 5FRYD3...GB021145
2016 MDX - SH-AWD - From VIN 5FRYD4...GB000001 thru 5FRYD4...GB061341
http://www.urvi.net/forumfiles/SB/B16-056.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-056.PDF
TSB 17-003 - AcuraLink Sending Excessive Notifications for Low Power
Applies To: 2014–15 MDX - Tech/Adv - ALL
2016 MDX - 2WD Tech/Adv - From VIN 5FRYD3...GB000001 thru 5FRYD3...GB016493
2016 MDX - SH-AWD Tech/Adv - From VIN 5FRYD4...GB000001 thru 5FRYD4...GB049096
http://www.urvi.net/forumfiles/SB/B17-003.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-003.PDF
TSB 17-008 - Buttons Sticking on Center Switch Panel/Interface Dial (Day/Night, SETTINGS, NAV, AUDIO, or others)
Applies To: 2014–17 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B17-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-008.PDF
TSB 17-009 - Product Update: MDX 9-Speed Transmission Warmer
Applies To: 2016 MDX - All - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B17-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-009.PDF
TSB 17-010 - Product Update: MDX 9-Speed Transmission Warmer (Transmission Previously Replaced for Transmission Warmer Leaking)
2017 MDX - All - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B17-010.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-010.PDF
TSB 17-026 - Warranty Extension: MDX Transmission Chirps During 3-4 Shift, Poor Shift Quality, or Engine Overheats Because of Defective ATF Warmer
Applies To: 2016 MDX - ALL - Check the iN VIN status for eligibility
2017 MDX - ALL - Check the iN VIN status for eligibility (Five MDXs affected)
http://www.urvi.net/forumfiles/SB/B17-026.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-026.PDF
TSB 17-034 - MIL Comes On with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank 2])
Applies To: 2014-16 MDX (except Sport Hybrid) - ALL - ALL
2017 MDX (except Sport Hybrid) - 2WD - From VIN 5FRYD3...HB000001 - 5FRYD3...HB014264 and 5J8YD3...HL000001 - 5J8YD3...HL000229
2017 MDX (except Sport Hybrid) - SH-AWD - From VIN 5FRYD4...HB000001 - 5FRYD4...HB040999 and 5J8YD4...HL000001 - 5J8YD4...HL000507
http://www.urvi.net/forumfiles/SB/B17-034.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-034.PDF
TSB 18-014 - Clicking from the Power Seat While Using the Height or Tilt Adjustment
2017-18 MDX Sport Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B18-014.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-014.PDF
TSB 18-033 - 2014-16 MDX: Steering Column Screeches When Moving
2016 MDX - 2WD - From VIN 5FRYD3H..GB000001 thru 5FRYD3H..GB020812
2016 MDX - SH-AWD - From VIN 5FRYD4H..GB000001 thru 5FRYD4H..GB060678
http://www.urvi.net/forumfiles/SB/B18-033.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-033.PDF
TSB 19-003 - MIL Comes On with DTC P0716
Applies To: 2016-17 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-003.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-003.PDF
TSB 19-005 - Multiple Indicators On and Option Fuse (E21 or B7) Blown
Applies To: 2016-19 MDX - ALL - ALL
2017-19 MDX Sport Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-005.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-005.PDF
TSB 19-011 - Safety Recall: 2016-18 MDX and 2015-19 TLX V6 Fuel Pump
Applies To: 2016-18 MDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-011.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-011.PDF
TSB 19-017 - Buzzing or Whining When Adjusting Front Seat Forward and Backward
Applies To: 2014-19 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-017.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-017.PDF
TSB 19-019 - Safety Recall: 2014-19 MDX Inner Lights
Applies To: 2014-19 MDX - ALL - Check the iN VIN status for eligibility
2017-19 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-019.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-019.PDF
TSB 19-027 - Service Manual Update: 2014-19 MDX and 2017-19 MDX Sport Hybrid Inner Taillight Sub Harness
http://www.urvi.net/forumfiles/SB/B19-027.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-027.PDF
TSB 19-029 - Warranty Extension: White Diamond Pearl Paint
Applies To: 2014-16 MDX - All vehicles painted White Diamond Pearl NH-603 - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-029.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-029.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2005-20 MDX
http://www.urvi.net/forumfiles/SB/B19-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF
TSB 20-015 - 9-Speed A/T Hard Upshift with Steady Acceleration
2020 MDX - AWD - From VIN 5J8YD4...LL000001 thru 5J8YD4...LL011456
2020 MDX - 2WD - From VIN 5J8YD3...LL000001 thru 5J8YD3...LL003798
http://www.urvi.net/forumfiles/SB/B20-015.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-015.PDF
TSB 20-022 - Service Manual Update: Second-Row Seat Frame Replacement
Applies To: 2014-20 MDX
2017-20 MDX Sport Hybrid
http://www.urvi.net/forumfiles/SB/B20-022.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-022.PDF
TSB 23-001 - Product Update: 2016-23 MDX PGM-FI Idle Stop Software Update
Applies To: 2016-20 MDX - All (except Hybrid) - Check the iN VIN status for eligibility
2022-23 MDX - All (except Hybrid & Type S) - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B23-001.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-001.PDF
TSB 23-002 - Warranty Extension: Engine Does Not Auto Restart After Entering Auto Idle Stop
Applies To: 2016-20 MDX (with 9A/T) - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B23-002.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-002.PDF
TSB 23-009 - Engine Does Not Crank
Applies To: 2016-20 MDX - ALL (except Hybrid) - ALL
http://www.urvi.net/forumfiles/SB/B23-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-009.PDF
TSB 23-036 - Safety Recall: 2015-20 Multi-Model Connecting Rod Bearing Stop Sale
Applies To: 2016-20 MDX - ALL (except Hybrid) - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B23-036.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-036.PDF
TSB 24-001 - Safety Recall: 2016–20 MDX Connecting Rod Bearing
Applies To: 2016-20 MDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-001.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-001.PDF
TSB 24-006 - Safety Recall: 2014–20 MDX and 2018–20 MDX Sport Hybrid Fuel Pump Motor
Applies To: 2014-20 MDX - ALL - Check the iN VIN status for eligibility
2018-20 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-006.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-006.PDF
http://techinfo.honda.com/rjanisis/p...B24-006 v2.PDF (Link works, but is wrong) Version 2
The following 5 users liked this post by EE4Life:
E92Vancouver (04-18-2018),
mexicodan (03-21-2023),
neoshi (09-15-2016),
ritches (03-20-2017),
Slowpoke842 (04-04-2017)
