2015 Acura MDX Technical Service Bulletins
Forum Contributor
Received 1,392 Likes
2015 Acura MDX Technical Service Bulletins:
TSB 13-039 - Ticking from the Dashboard or Front Damper
Applies To: 2014-15 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B13-039.PDF
http://techinfo.honda.com/rjanisis/p...nu/B13-039.PDF
TSB 14-010 - 2015 MDX: TQI Information
Applies To: 2015 MDX - All
http://www.urvi.net/forumfiles/SB/B14-010.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-010.PDF
TSB 14-011 - 2015 MDX: TQI of the Navigation System
Applies To: 2015 MDX - All with Navigation
http://www.urvi.net/forumfiles/SB/B14-011.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-011.PDF
TSB 14-025 - Timing Belt Chirps
Applies To: 2014-18 MDX - ALL - ALL
2019 MDX - 2WD - From VIN 5J8YD3...KL000001 thru 5J8YD3...KL005096
2019 MDX - AWD - From VIN 5J8YD4...KL000001 thru 5J8YD4...KL011104
2019 MDX Sport Hybrid - From VIN 5J8YD7...KL000001 thru 5J8YD7...KL000483
http://www.urvi.net/forumfiles/SB/B14-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-025.PDF
TSB 14-031 - Steering Column Screeches When Moving
MDX was removed from this bulletin. Refer to service bulletin 18-033, 2014-16 MDX: Steering Column Screeches When Moving.
TSB 14-037 - Client Satisfaction Improvement Campaign: Update for 2015 MDX and TLX ODMD (Vehicles with Navigation)
Applies To: 2015 MDX - All with Navigation - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B14-037.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-037.PDF
TSB 14-038 - Safety Recall: Front Seatbelts Will Not Extend or Retract Properly in Extremely Cold Weather
Applies To: 2014-15 MDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B14-038.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-038.PDF
TSB 14-045 - Power Steering Buzz or Grunt After Shifting From Reverse
Applies To: 2014 MDX - ALL
2015 MDX - 2WD - From VIN 5FRYD3H4.FB000001 thru 5FRYD3H4.FB006937 and 5FRYD3H8.FB000001 thru 5FRYD3H8.FB007398
2015 MDX - SH-AWD - From VIN 5FRYD4H4.FB000001 thru 5FRYD4H4.FB016167 and 5FRYD4H8.FB000001 thru 5FRYD4H8.FB016387
http://www.urvi.net/forumfiles/SB/B14-045.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-045.PDF
TSB 14-048 - New Warranty Instructions for TPMS-Related Repairs
http://www.urvi.net/forumfiles/SB/B14-048.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-048.PDF
TSB 15-007 - MIL Comes On With DTC P0134 /P0154
http://www.urvi.net/forumfiles/SB/B15-007.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-007.PDF
TSB 15-017 - AcuraLink System Status Indicator Is Red and DTC B1403 Will Not Clear
Applies To: 2014 MDX - ALL with navigation - ALL
2015 MDX - 2WD with navigation - From VIN 5FRYD3...FB000001 thru 5FRYD3...FB007880
2015 MDX - SH-AWD with navigation - From VIN 5FRYD4...FB000001 thru 5FRYD4...FB018838
http://www.urvi.net/forumfiles/SB/B15-017.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-017.PDF
TSB 15-023 - HomeLink System Has Weak or Limited Range
Applies To: 2014–16 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B15-023.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-023.PDF
TSB 15-029 - Safety Recall: MDX CMBS Error
Applies To: 2014–15 MDX - Advance and Advance SH-AWD - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B15-029.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-029.PDF
TSB 15-036 - HVAC Display Flashes or Flickers
Applies To: 2014–15 MDX - ALL with navigation - ALL
http://www.urvi.net/forumfiles/SB/B15-036.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-036.PDF
TSB 15-037 - Safety Recall: A/C Compressor Clutch Bolt
Applies To: 2014–15 MDX - ALL with 2WD - Check the iN VIN status for eligibility
2014–15 - MDX - ALL with SH-AWD - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B15-037.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-037.PDF
TSB 15-046 - Security System Sounds or May Not Set
Applies To: 2014–15 MDX - ALL - ALL
2016 MDX - ALL 2WD - From VIN 5FRYD3H..GB000001 to 5FRYD3H..GB007326
2016 MDX - ALL SH-AWD - From VIN 5FRYD4H..GB000001 to 5FRYD4H..GB029373
http://www.urvi.net/forumfiles/SB/B15-046.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-046.PDF
TSB 15-053 - MIL Comes On with DTC P0430
This bulletin is replaced by S/B 17-034, MIL Comes On with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank 2])
http://www.urvi.net/forumfiles/SB/B15-053.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-053.PDF
TSB 16-001 - Remote Engine Start System Poor Range Performance
http://www.urvi.net/forumfiles/SB/B16-001.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-001.PDF
TSB 16-008 - High Pressure Fuel Pump Chirps
Applies To: 2014-17 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B16-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-008.PDF
TSB 16-031 - Power Tailgate Won’t Open from the Outside in Cold Weather
Applies To: 2015 MDX - ALL - ALL
2016 MDX - ALL - ALL
2017 MDX - 2WD - From VIN 5FRYD3H..HB000001 to 5FRYD3H..HB006289
2017 MDX - SH-AWD - From VIN 5FRYD4H..HB000001 to 5FRYD4H..HB018917
2017 MDX SPORT HYBRID - ALL - From VIN 5FRYD7H..HB000001 to 5FRYD7H..HB000041
http://www.urvi.net/forumfiles/SB/B16-031.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-031.PDF
TSB 16-032 - Safety Recall: 2015–16 MDX Fuel Tank
Applies To: 2015-16 MDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B16-032.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-032.PDF
TSB 16-035 - Rattle or Clunk from the Rear Suspension
Applies To: 2014-16 MDX - ALL with 2WD - ALL
2014-16 MDX - ALL with 4WD - ALL
http://www.urvi.net/forumfiles/SB/B16-035.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-035.PDF
TSB 16-042 - Squeak and/or Pop from the Front Suspension While Turning
2014-16 MDX - ALL with SH-AWD - ALL
http://www.urvi.net/forumfiles/SB/B16-042.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-042.PDF
TSB 16-056 - Power Tailgate Does Not Work
2016 MDX - 2WD - From VIN 5FRYD3...GB000001 thru 5FRYD3...GB021145
2016 MDX - SH-AWD - From VIN 5FRYD4...GB000001 thru 5FRYD4...GB061341
http://www.urvi.net/forumfiles/SB/B16-056.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-056.PDF
TSB 16-062 - 2012–15 MDX: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required)
Applies To: 2012 MDX - ALL - From VIN 2HNYD2H...CH513517 thru 2HNYD2H...CH550713
2013 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B16-062.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-062.PDF
TSB 16-063 - 2012–15 MDX: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Upload Required)
http://www.urvi.net/forumfiles/SB/B16-063.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-063.PDF
TSB 17-003 - AcuraLink Sending Excessive Notifications for Low Power
Applies To: 2014–15 MDX - Tech/Adv - ALL
2016 MDX - 2WD Tech/Adv - From VIN 5FRYD3...GB000001 thru 5FRYD3...GB016493
2016 MDX - SH-AWD Tech/Adv - From VIN 5FRYD4...GB000001 thru 5FRYD4...GB049096
http://www.urvi.net/forumfiles/SB/B17-003.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-003.PDF
TSB 17-008 - Buttons Sticking on Center Switch Panel/Interface Dial (Day/Night, SETTINGS, NAV, AUDIO, or others)
Applies To: 2014–17 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B17-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-008.PDF
TSB 17-034 - MIL Comes On with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank 2])
Applies To: 2014-16 MDX (except Sport Hybrid) - ALL - ALL
2017 MDX (except Sport Hybrid) - 2WD - From VIN 5FRYD3...HB000001 - 5FRYD3...HB014264 and 5J8YD3...HL000001 - 5J8YD3...HL000229
2017 MDX (except Sport Hybrid) - SH-AWD - From VIN 5FRYD4...HB000001 - 5FRYD4...HB040999 and 5J8YD4...HL000001 - 5J8YD4...HL000507
http://www.urvi.net/forumfiles/SB/B17-034.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-034.PDF
TSB 18-014 - Clicking from the Power Seat While Using the Height or Tilt Adjustment
2017-18 MDX Sport Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B18-014.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-014.PDF
TSB 18-033 - 2014-16 MDX: Steering Column Screeches When Moving
2016 MDX - 2WD - From VIN 5FRYD3H..GB000001 thru 5FRYD3H..GB020812
2016 MDX - SH-AWD - From VIN 5FRYD4H..GB000001 thru 5FRYD4H..GB060678
http://www.urvi.net/forumfiles/SB/B18-033.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-033.PDF
TSB 19-017 - Buzzing or Whining When Adjusting Front Seat Forward and Backward
Applies To: 2014-19 MDX - ALL - ALL
2017-19 MDX Sport Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-017.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-017.PDF
TSB 19-019 - Safety Recall: 2014-19 MDX Inner Lights
Applies To: 2014-19 MDX - ALL - Check the iN VIN status for eligibility
2017-19 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-019.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-019.PDF
TSB 19-027 - Service Manual Update: 2014-19 MDX and 2017-19 MDX Sport Hybrid Inner Taillight Sub Harness
http://www.urvi.net/forumfiles/SB/B19-027.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-027.PDF
TSB 19-029 - Warranty Extension: White Diamond Pearl Paint
Applies To: 2014-16 MDX - All vehicles painted White Diamond Pearl NH-603 - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-029.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-029.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2005-20 MDX
http://www.urvi.net/forumfiles/SB/B19-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF
TSB 20-022 - Service Manual Update: Second-Row Seat Frame Replacement
Applies To: 2014-20 MDX
2017-20 MDX Sport Hybrid
http://www.urvi.net/forumfiles/SB/B20-022.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-022.PDF
TSB 24-006 - Safety Recall: 2014–20 MDX and 2018–20 MDX Sport Hybrid Fuel Pump Motor
Applies To: 2014-20 MDX - ALL - Check the iN VIN status for eligibility
2018-20 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-006.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-006.PDF
http://techinfo.honda.com/rjanisis/p...B24-006 v2.PDF (Link works, but is wrong) Version 2
The following 3 users liked this post by EE4Life:
