Winter tires help
Winter tires help
Hi guys.. I bought a set of winter tires and steelies from a 2007 honda accord as per the seller. The specs are 205x60x16. I look it up online and the hub bore size of the 2007 accord is the same as my 2012 tsx which is 64.1mm.
When I installed the steelies the hub bore is too big and measured at 70.1mm. Can I still use this or is there a hub centric ring that I can purchase? Also can I use my oem lugs on these steelies?
I live in Canada and need these winter tires anytime soon Appreciate your help in advance!
1/ The tire size appears to be OK (diameter variance -0.67 compared to the original 225/55/17). The narrower tire would actually work really well in snow.
2/ The steel rims appears not to be hub-centric - Looks like the original rim owner got some generic rims (e.g., from costco). I don't think you can use a ring on steel rims.
I personally would not use non-hub-centric rims on any of my cars - you are relying on the lungs for properly centering the rim and this may cause issues such as vibrations, etc. not to mention fatigue problems on the bolts themselves.
Hub rings are used to assist in installation of the wheel. They are not needed for centering or holding the wheel once it is bolted on.
You don't need centering rings. But they help for installing the wheel.
If you decide you want centering rings, a tire shop will almost surely have some in stock for you.
xtcnrice (11-30-2015)
