Will 245 45 19 tires work/look good on stock suspension?
1 Attachment(s)
Hi, I picked up a set of 19x8 grey Maxima Sport rims to put on my 2nd gen TSX. I am on stock suspension and do not plan on lowering anytime soon. Would 245 45 19 tires rub and if not, will they look good? I like the wide tires and want good protection from potholes as I drive over a lot of poorly maintained roads. Would I be better off going with 245 40 19 tires? Any help would be greatly appreciated.
245 45 19 are too tall.
If you want 245's on a 19 you'd be better off with a 245 35 19 tire. More closely matches your original 225 50 17's. Google search Tire Diameter Calculator and look for yourself. |
Alright thank you. Will I have any figment issues with 245 40 19?
Originally Posted by Lieu14
(Post 16424294)
Tire size calculator on google, my friend. 245/40 is too tall and your speedometer will be off. They my also look odd. Whether they FIT depends on a lot of things. Also...is the Nissan centrebore big enough for an Acura hub? Remember to use the same lugnut style as Nissan does, BTW. Your stock lug nuts will not work properly. |
(Post 16424294)
