Wheel setup question?
Hello Guys,
Need help, i try to do 19" on my 2010 tsx
19x8.5 in the front
19x9.5 in the back
offset around 38-42
will that work?
do i need to roll finder or do camber kit
if any memeber have picture of same setup can i see it so i can get an idea how it look
also i plan to lower the car also
thank you
19x8.5 in the front
19x9.5 in the back
offset around 38-42
will that work?
thank you
You should be fine if you run 245 tires on the back but also depends how big would be the drop but it wont hurt if you roll your fenders to be safe there are people running 9.5 on the back I have 19x8.5 all around 35 offset with 1 inch drop check out my thread
https://acurazine.com/forums/2g-tsx-photograph-gallery-144/new-shoes-my-tsx-792220/
https://acurazine.com/forums/showthread.php?t=792220
this is going to be my set up 19x8.5 offset 38-42
lower with S-tech spring
245/35/19
what to see how that look....Nice...
ooh yea...add the new Front lip ...yea...
245/35/19
what you think of this set up.
XXR 527 18x8.75 Gold 5-100/5-114.3 [+35mm]
i plan to do like 235/45/18 ?
what you think.
