Volk GT-U 18" x 8" set up on '10 TSX
I just bought volk racing GT-U 18 x 8 +43 offset for my 2010 TSX 6MT.
I'm going to lower 1" with Eibach Pro-kit.
What size tires should I get? 235/40 or 235/45?
I want to fill up the gap but don't want to rub or need to roll fenders.
Also, I did research and found that +43 offset is acceptable, but will it look funny? Will the wheels stick out too much?
Any help would be much appreciated!!
Use this:
http://www.1010tires.com/TireSizeCal...?action=submit
235/40s will have shorter sidewall height (fill less of the wheel gap) and the speedo will read faster than your real speed. 235/45s will be taller and the speedo will read slower. Both are off by less than 2%, but you can also consider something like 245/40 or 225/45 which are closer to stock diameter, although 225 series IMO looks too small. Personally, I'd do 245/40.
More tools here:
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/wheel-tire-fitment-resources-821398/
More tools here:
These are 18 x 8 with a +39mm offset. I currently have 235/45's on them, but I'm switching to a 225/45. 235's round out a bit too much, giving it a 'bubbly' appearance on the rim. The 225 has a cleaner fit. My +39mm offset lines up with the fenders nicely. The 235/45 actually made the tire stick out ever-so-slightly beyond the fender, as you can see in the pics. Your set up will be fine.
Jeroplex...ended up going to 245/40/18. Think that was the right fit.
Only thing i did was get these Volk GTU's 18x8 and dropped it. Oh, also got rear camber arms.
I'm pretty satisfied. I think the offset in the front is perfect. However, I probably could have gone up to +39 in the rear. But I bought the wheels used so I'm pretty satisfied on how they fit.
I'll try to get more pics up.
acura_dipset_tl
Jan 1, 2016 03:02 PM
braveheart
Sep 7, 2015 08:12 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
