Varrstoen Offset Question
8th Gear
Hello all,
I've been searching the site for a couple of days now and i'm trying to figure out what works and what doesn't. I found a set on Ebay 19x9.5 es2 +12. I know that this is going to need fender work and was planning on running a 235-35-19 for a tire.
Should I be looking for different offsets to make my life easier? If so what should the ideal offsets be for a 2g with the 19x9.5.
Thanks in advance,
Steve
Thanks in advance,
Steve
I had varrstoens before. 19x9.5 +30 front and +22 rear. I bought them in this size hoping to be flush on simply rolled fenders, no pull yet. By the time I actually put them on though, I had a new financed TSX and so I was able to do all the fender modifications I wanted. So I did, and I flared out all my fenders, cut the liner, relocated the bumper tab etc. Once I put the wheels on, they were no longer aggressive because they were sitting so sunk inside the wheel well.
Thus, my opinion is..as silly as it sounds: if your willing to do fender work, and willing to stretch a tire etc., I think you should just buy the wheel you want first in the size that you want, and then try and make the car fit the wheel. That way, you can modify the fender as necessary to get the exact look you want. One of our members, cwins or something has 18x9.5 +12 varrstoens on his car now so it is definitely doable. Anything in the 12-30 offset range and 9"-10.5" is aggressive for our cars so get anything in that general size and just test fit the wheel, and do the fender modifications as you see fit. My 2 cents for those people who are going to do custom fender work.
our cars can run pretty wide, i have a friend on 20x10.5 +15 on stock camber and his fitment is spot on. Which made me condfident enough, for my next set of wheels to run 18x9.5 and 18x11 in the rears. so really all you need to worry about is making your fender work with your wheels but as ttk said anytinh along the 12-30 range its very doable with little to no work done. id say most youd have to worry about is a fender pull.very very slight pull.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
