Two tire size choices
Old 04-20-2011, 03:53 PM
cabanalane's Avatar
Exclamation Two tire size choices
For OEM 17s.
225/55/17 or 235/50/17.
Can you tell me the pros and cons of these two sizes?
Old 04-20-2011, 04:26 PM
Op is too busy to care
KillerG's Avatar
wall is a bit thinner, tires a tiny bit thicker on numero dos, wont notice a big difference either way, idk
id go with choice 1 out of simplicity
Old 04-20-2011, 04:33 PM
cabanalane's Avatar
My reason for this is. The OEM 225/50/17 look a bit small. The 235/50 would make it look a bit meaty. However, there is the wheel gap. 225/55 would be taller, so therefore fill up the gap better.
And don't want to lower it or get bigger 18" wheels.
Old 04-20-2011, 04:43 PM
KillerG's Avatar
well thinning out tires on a tiny wheel might just make them even tinier than they already are
50s will just make the gap look gappier
if your are not willing to do anything else then just leave it stock.
Might i suggest though, an option?
Eibach springs (1/1) for like ($175) and rear/front spacers (15mm ichiba ver2) ($200) will make the stock tsx look mean on the dime.
dunno if you can save by skipping tires but i think the stockies look good, they just need a slight drop and to be pushed out
Old 04-20-2011, 04:55 PM
cabanalane's Avatar
I agree with this statement 100%.
ron3.7
09-20-2015 11:39 PM
GhostTL09
09-19-2015 01:57 PM
coykiam
09-11-2015 03:43 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Two tire size choices
