Which tire size? 255 40 or 245 45 for example
Old 10-18-2017, 10:26 AM
TSX1012m6's Avatar
2012 TSX - Using TL Type S 17" wheels. Was thinking of going with two sets of wheels and throwing winters on these TL wheels but I'm just going to go with a set of all seasons and if I get another set of wheels I throw summer tires on them.
Which size would work/look best on a stock suspension? I like the idea of the extra wheel width with 255's (the rims I have a pretty heavy though). TL owners were reporting 255's with a 40 sidewall, but im wondering if its getting too close to a rubber band looking tire with the very high wheel well gap our TSX's have. I'm afraid it would look silly. Can anyone make a recommendation?
Old 10-18-2017, 12:15 PM
BROlando's Avatar
Received 1,163 Likes on 874 Posts
I think I've suggested just buying 18's and using 245/40/18 before.
If you're decided on buying another set of 17's to round out the two sets of 17's you already have...245/45 is slightly smaller than the stock 225/50...and 255/45 is slightly larger than the stock 225/50.
Both are about a 4mm deviation from the stock rolling diameter.
Old 10-18-2017, 12:17 PM
BROlando's Avatar
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/looking-purchase-new-rims-957869/
Old 10-18-2017, 12:38 PM
TSX1012m6's Avatar
You gave great suggestions. My next wheels will not be 17" - I'm interested in the specific tire size/wall/width for my current 17"s. Now that I have a 8 inch rim I'm wondering if 255's are the way to go.
The stockers I have are not in the best shape. Bought the car with a bit a curb rash and unknown to me two wheels were safe but dented on the inner wheel. I do not plan on putting them on the car until I sell it.
Old 10-18-2017, 12:46 PM
BROlando's Avatar
Nominally, a 255 is slightly over 10" wide (255mm).
You would want at least 9 or 9.5" wheels to accomodate them. They will "square out" on a 9.5" wheel.
A 255 will be pinched pretty badly on a 8" wide wheel. So will a 245, for that matter.
Aesthetics aside, in terms of optimizing the tyre...235mm is about the max you'd want on a 8" wide wheel. Even that is a little much.
**referring to tyres in the sidewall heights that pertain to the TSX.
Old 10-18-2017, 01:04 PM
TSX1012m6's Avatar
255's are definetly pinched in. I'm not going to go that route, after some research 255 40 will not fit on an 8" rim (45 sidewall would though). I have 225 on there now. The lip of the wheel sticks a little less than 1/8". The sidewalls of the tire are not flush with the rim. The type S came with 235's on them.
235:
245:
255 (this confirms that 255 40 will not work, but a 45 side wall will)
I'm also thinking to try to stay at a 45 sidewall. With the wheel gap, a 40 sidewall will just look silly on a a set of wheels that already look small on the car. I know, I just LOVE the Type S wheels.
Old 10-18-2017, 01:19 PM
BROlando's Avatar
Yes, a taller sidewall will make a tyre work at narrower rim widths. Trucks have 265's on 7.5" wheels, for example.
But aesthetically, it will still look pinched. Aesthetics are viewer dependent. I like my tyres to "square out". Though, a pinched tyre is my preference over a stretched tyre.
A 255/45 or 245/45 is within (+/-) 4mm of the stock rolling diameter, as mentioned prior.
255/40 is the incorrect size for a 2G TSX. Your speedometer would be off considerably.
Old 10-18-2017, 01:26 PM
TSX1012m6's Avatar
Great points. I believe you have already said 235, but in this scenario would you go with 235/45 or 245/45? I personally like the idea of a slightly wider tire, 235 is a nice jump from 225 regardless.
Old 10-18-2017, 01:32 PM
BROlando's Avatar
245/45 is closer to the stock diameter. I'd probably go with that.
TSX1012m6 (10-18-2017)
Old 10-27-2017, 10:21 AM
TSX1012m6's Avatar
I'm very happy with 245/45/17. Car drives great and grips fantastic. Haven't had a chance to drive in wet weather yet. Road noise is minimal as well. Went with BF Goodrich geforce comp-2 AS
Old 10-28-2017, 12:40 PM
BROlando's Avatar
Looks great, bruv
Old 02-21-2018, 12:57 AM
Alex Unimos's Avatar
WOW those are some beefy looking tires bro!
