Requesting some helpful advice re: wheels and tires
I'm looking at purchasing some oem wheels... ones I have in mind are the 02 CL-S 5 star which I believe are 17x7, or the TL waffles.
I have an 05 TSX and I am wondering if both of these will fit cause I know the bolt patterns match, just the hub and bore I don't know anything about???
Also I'm wondering what's the best tire size for semi agressive look on 17" wheels??? I was thinking 225/45/17?? Or even 235/45/17???
My tsx is lowered with eibach springs....
Current set up is 255/40/17 front, 215/50/17 rear on BBS mesh
(Came with the car, I purchased it as write off. It is also cocaine white)
I appreciate any thoughts and input.
I've been running OEM BBSs off an STi for a couple of years. They are forged, 17x8" and 53+ offset, which isn't easy to find with aftermarket wheels. Same bolt pattern, all that needs to be done is center bore needs to be machines larger. I'm running 235/45R17 tires, works very well.
Stan
Stan
lmc
01-09-2016 05:25 PM
Jimmy_D
01-07-2016 07:18 AM
