Rear Sway bar
Rear Sway bar
Hey guys, looking for a rear sway bar....is the only one out there the progress one? and do you have to drill it? Im sorry if there already is a thread out there i just cant seem to find it....also anyone have any recommendations for wheels spacers so i can get that flush look? Thanks i appreciate it guys, i really do!
SeeYou2Crew #2
i think progress is the only sway bar, UR brace has a few braces for the car, but idk if there is a RSB.
and you do have to drille it, but i think people found ways to go around it with some special mounting materials.
All im looking for is to improve handling, take it to the next level...i have springs and i have wheels and tires...i have the upgraded rotors and pads...and i dont have 1500 to drop on coils hahaha
Thats what im saying....hmmmm...maybe ill have to pull a republican and DRILL BABY DRILL
Alright, you might be getting an order for that extremely soon
Alrighty, i have to go measure since im not 100% sure hahaha but i believe they are 45+
just looked at my photo gallery thread and they are +45!
I just installed my Progress RSB today. It was freakin' cake. And the drilling? I did it with an 18V cordless and a 13/32" drill bit. Took me about two minutes to drill out with a 3/8" bit, then I re-drilled with the 13/32". I did that because I was using the cordless. Not a lot of power but it still did the job perfectly. I was against drilling at first but after I got the thing on a lift and took a good look at it I was like, why the hell was I even nervous? Seriously. Drill the damn thing. It won't hurt anything. Just be sure to spray the lower links with break-free or liquid wrench and let it soak for a few minutes before torquing on it. If you strip that 5mm allen bolt, you are screwed. And another thing, if you are like me and don't like ripping every single suspension piece out of place, you can get the ba mostly in position without removing anything but then once you get it over the exhaust you can remove either the left OR right caliper (yes, only one) and it'll go right into position.
And despite the fact that there is a workaround for drilling, do you really want to alter the specs? I doubt it'll function the same when you start adding other parts. Something to consider. To each their own.
Handling? Freakin' outstanding and I'm rollin' on stock suspension other than the sway bar. It tracks with a lot less understeer which is perfect for my driving habits and quite a bit less roll. Great mod. Just drill and get it over with.
Former Sponsor
We have plenty in stock if anyone wants one.
http://store.excelerateperformance.c.../i-248908.aspx
Former Sponsor
mrstak (09-21-2011)
So i put this on my car and just like tannis said the handling is unbelievable....ordered it from XlR8 and they shipped it to me extremely quickly! and I put it on saturday....and with the springs its insane...little to no body roll and your confidence goes up so much! ITS INSANE
Just get under there. Once you start you'll see exactly how easy it really is.
Now i want one too, you guys are dicks
I just saw it on your website.
I believe out stock bar is already 19mm, if thats correct then progress is still the way to go?
Have heard great feedback on both the 19mm and 22mm sway bars from UR and Progress.
woops, my mistake
one last question, is the UR bar direct bolt on for the 09 TSX or does it require some drilling too?
and ANOTHER quick question, lets say im installing springs, it makes sense to install the RSB at the same time right since ill be unlinking some of the same components?
and ANOTHER quick question, when i lower, should i just install camber arms at the same time immediately or wait till get an alignment and see whats good?
22mm we don't have up yet and will cost more than the Progress 22mm. Pricing would be around 219 shipped approx based on what we have seen the other 22/23mm rear sways from UR go for. Similarly we can package items with the braces (we have them all in stock). We are the direct importer (are even listed on UR's main website) into the US.
Good question - I'd say it depends on your drop expected. If you are going very mild and are in between a 1-arm and a 3-arm (and possibly have free alignment) then it may be worth buying the arms after finding out what your camber is. For most I recommend buying the camber arms when buying a suspension (coilovers, springs) and installing at the same time (lay the arms down on the ground next to the OEM and adjust them to about the same size). This way it will only take one alignment for the shop to get you back into spec. My general rule from what I've seen on the 8th gen Accords is that a 1-arm will be okay for a drop up to about 1.5" but anything after and especially if you want coilovers I'd recommend the 3-arm as any further adjustment of just the camber arm will begin to throw off the toe, etc.
another question what would be the handling diff between the 19mm and the 22mm are there any adverse effects of getting a thicker one im sorry i dont quite understand why anyone would get a thinner one unless it ruins ride quality or something else I dont know
to those that installed the progress sway bar, which setting did you use? I'm going to install mine in the next couple days and curious on which hole? I was just gonna do the stiffest, anyone?
a bigger rear sway bar would cause more oversteer.
Went with the stiffest setting and never looked back...I had this installed on my 09 TSX a while back (even had HeelToe install it and he used it for install photos on his website) and loved it! I'll probably also get this on my '11 as well...
TSX section isn't fully linked over, but here's the link to all bars including the FSTB.
http://throwdownperformance.com/inde...=219_1_2_4_225
marcelft
07-10-2018 06:17 PM
MonkeyTrucker
09-21-2015 06:15 PM
k6biv
09-10-2015 06:37 PM
