Offset question for CU2 TSX
Old 04-26-2013 | 08:45 AM
number17's Avatar
I'm looking for new rims and I'm wondering what kind of offset I should go for.
I realize the stock setup with 55 offset both F and R rims are quite recessed in the wheel well (not sure why Honda does that but anyways ... )
I also notice the R is even more recessed than the F with 55 offset.
I want to make both F and R flush with the fender, but not stick out ... what kind of offset should I go for?
I am not sure about staggered setup for rims, so I could put in a wheel spacer for the R if I must.
If I just eyeball it I should go with a 45 offset for F and R, and add 5mm spacers for the R?
What do you guys think?
I won't lower (roads are too bad around here) and don't want to roll my fenders.
Thanks in advance
Old 04-26-2013 | 04:48 PM
apinwp09GBTSX's Avatar
Not lowering stay stock especially if your planning to go with bigger rims; just my opinion!!
Old 04-26-2013 | 05:17 PM
SlickxAc's Avatar
^THIS! if your roads are that bad, its better to stay with stock wheels since you will have more tire.
Old 04-27-2013 | 09:16 PM
Simba91102's Avatar
Old Guy
Thanks in advance
45 offset will give you a nice 10mm increase in track with zero concerns about fit. They'll make the wheelwells look fuller too. I'd skip the spacers; the front and rear track are the same (62.2"), and the new wheels will look fine without them.
Old 04-28-2013 | 11:48 AM
stan_t's Avatar
Why are you only concentrating on offset? 8 1/2" wide 55 offset wheel will stick out 13mm compared to stock 7 1/2" wheels.
Stan
BreezyTL
07-26-2016 12:52 PM
V-tecAc
09-21-2015 09:25 AM
datadr
09-12-2015 09:12 PM
nuldabz
09-03-2015 05:49 PM
bailey24
08-31-2015 05:38 PM
Quick Reply: Offset question for CU2 TSX
