OEM top hats part numbers
Does anyone have a complete parts list and corresponding part numbers for OEM top hats? I am referring to the parts needed to install new coilovers without reusing my stock parts.
VTEC just kicked in, yo!
Luckily I did the research back in 2014 when I installed my TEINs . Here are the parts I needed for all 4 corners of my 4 cylinder TSX sedan:
Gary
- 51686-TA0-A01 (x2) RUBBER, FR. SPRING MOUNT
- 51631-SL0-003 (x8) RUBBER, SHOCK ABSORBER MOUNTING
- 51728-SR0-003 (x4) COLLAR, SHOCK ABSORBER MOUNTING (DUFFY STEEL PARTS)
- 51675-TA0-A02 (x1) BASE, R. FR. SHOCK ABSORBER MOUNTING
- 51676-TA0-A02 (x1) BASE, L. FR. SHOCK ABSORBER MOUNTING
- 51621-S84-A01 (x4) WASHER, SHOCK ABSORBER MOUNTING
- 51685-SR0-004 (x4) PLATE, DUST COVER (SHOWA)
- 52675-TL1-E01 (x2) BASE, RR. SHOCK ABSORBER MOUNTING
- 52686-SDA-A01 (x2) RUBBER, RR. SPRING MOUNTING
Gary
Gary
Gary
julius071 (06-22-2018)
Heeltoe sells a kit of everything you need.
https://www.heeltoeauto.com/honda-ge...a-tsx-cu2.html
Also bought my flex Z from them. Marcus is great and has been around for awhile - very trustworthy.
Marsaloni
02-28-2013 08:23 AM
feuss2
07-11-2010 11:47 AM
jguerra23
06-07-2009 06:55 PM
