Need new sway bar endlinks (front and rear), any suggestions?
Hey everyone! So my TSX has been making a knocking sound when going over bumps for the past year, so I took it to the mechanic today to get it inspected. I was pretty sure it was the sway bar endlinks for the front, but I told the mechanic to check for worn bushings throughout the car's suspension. The mechanic later showed me the sway bar endlinks going bad on all 4 sides. Now the issue I have is that I want to buy more durable endlinks since my car has been lowered on coilovers recently, but I can't find too many options that would work with our CU2. Does anyone have suggestions for what I could replace my worn swaybar endlinks with?
You're not going to find links that last LONGER than stock.
Coilovers don't put any extra stress on swaybar links, BTW.
Check your coilover tophat nuts (the big one in the center of the tophat). They can sometimes come loose. Don't use an impact or any power tool.
On another note, are universal end links a thing? I've been looking at some of them, like the ones made by Energy Suspensions, but I'm not sure if they'd work on our cars.
This car uses ball jointed end links. No idea what a universal end link is. Unless they're referring to using two ball/socket joints and a turnbuckle. That would work if you needed adjustable links. You can buy all that on McMaster Carr or source it from Aurora bearing. But you'd be dealing with race car problems afterward. For no reason.
Those aren't universal in either case. You need parts that will fit the car's mating parts.
Ended up going with Proforged front end link and Moog rear end links which I got from Summit Racing. Car feels much better now especially with the ST suspensions sway bar I installed too. Think I still need to get my lower control arm bushings replaced though.
