Installed VMR V710, Tein S-tech's. (REVIEW)
Just had the pleasure of receiving my VMR V710 wheels from Tracy at VMR. What a breeze to talk to and deal with, helped me every step of the way. Shipped me my lug nuts with my wheels, got here right when he said they would. I highly recommend going through them not only for their customer service but their quality wheels. They're better in person than in pics.
The Tein S-tech's ride very smooth and gave me the perfect drop I was looking for.
For reference the wheels are 18x8.5 et35 with 235/40/18 hankook v12's
I don't think the front springs had settled yet in the first pic
VMRWheels (04-07-2016)
Looks good, wellcome to the forum!
ROTAREDOM
Why did you get new Lugs?
ROTAREDOM
Really? I used my OEM lugs with Enkei Razr no problem. Is there I smaller mounting base for the lug to sit flush?
ROTAREDOM
Who would have thunk it?! Good info, I never even thought twice about it to be honest.
xtcnrice (04-07-2016)
Just remember to carry a set of OEM lug nuts for the spare tire for if/when something happens to your summer tires!
Likewise, make sure your tire iron fits your aftermarket lug nut adapter.
VTEC just kicked in, yo!
This. I carry 5 OEM lug nuts (4 regular, 1 locking) under the trunk, where the spare and parts are. You don't want to go through the effort of changing a flat on your own with an OEM scissors jack on a lowered car, only to find out you can't secure your wheel after all the work you went through!
ROTAREDOM
Order a set of what?
Former Sponsor
Thank you so much for sharing!
Former Sponsor
^ This is true and correct. Although, once we determine proper ball seat size ( R13? ) then we can also suggest lug nuts that fit too. Conicals are the tried and true aftermarket lug style though!
This is also true. I don't recommend this at all: but I once had to use my donut and tried to tighten them down with my Kics R40. They worked, but I had to pull over and retorque the lugs every 5 miles or so and drove street only.
Also, that lug key should fit standard 17 or 19mm socket ( I don't recall which one ATM. Can you confirm, Corradovrsick? )
ROTAREDOM
So if one were to buy V710FF for the TSX these lugs would work fine??
20 12x1 5 Red 6 Spline Tuner Lug Nuts 2 Keys Fits Honda Acura | eBay
VMRWheels (04-11-2016)
The socket size is 19mm, I ran a 40 because I had perfect condition hankook Ventus v12's laying around so I figured it wouldn't matter.. Which it doesn't, still looks good rides good and doesn't rub so I'm happy with it
Former Sponsor
Although I should say this with the disclaimer:
* Only run the recommended tire size for your vehicle. Running a smaller/larger diameter than what's recommended may result in speedo reading higher/lower, improper odometer readings, ABS and traction control issues and more.
235/40/18 is a bit short. Its about 0.35" shorter than stock. Not much.
235/45/18 is about .48" taller than stock.
235's make it so that there's no direct match. But 235/40/18 is closer to stock than 235/45/18.
xtcnrice (04-19-2016)
