G37 oem 19s fitment
G37 oem 19s fitment
I am considering getting a set of these. However, I am unsure of fitment due to the wheels being staggered. Here are the specs. Seller said hes still got the original tires on em (but I will be take them off and mount 245/35/19 all the way around before installimg on the car)
Front:
Wheels: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear:
Wheels: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
I understand that staggered set ups will just amplify understeer in fwd cars, but i dont track my car nor push it often.
Thanks for any help in advance.
Front:
Rear:
Yeah. I saw his car before and thought the wheels looked absolutely beautiful on the TL. I was hoping itd do the same for the TSX. But I wanted to get some fitment opinions from the gurus on here before diving in.
I agree with ed423, these should fit no problem. For comparison, I have 19x8.5, +42mm offset, no issues at all, and I'm not even one of the more aggressive setups on this forum (defconskylude, kowloonsniperhk, are others with more aggressive setups that come to mind).
I have 19x9 +45 on my car and they are fine.
i modified a set of them to put on my 8th gen accord. the hub is 66.1 and the acura is 64.1. you cant get a hubcentric ring that small, so to avoid vibrations, you will need to CnC the hub larger to use a ring. the offset should be fine though. i ran staggered with no issues (though i used the same size tires all the way around).
pics below:
pics below:
any side shots? that looks really good
sharkbreath's are the same as mine, not the same as the G37. Ours are G35, which are 19x8 33 front, and 19x8.5 30offset in the rears.
You won't have any issues at the G37 size/offset, should look really good, and i think the 245/35 will be the right size to run both F&R. Depending on the suspension you are running and the 'look' you prefer, it may or may not be a little too offset (not out to the fenders enough), which you could use 5mm spacers on front and 10mm on the rear to get them out to where i would personally like them the best.
I'd show you how my setup looks by comparison, but my suspension install got delayed this week due to me getting the incorrect coilovers sent to me, waiting on the re-ship. Once I get them installed, I'll post pics, because as of now with the 19's it looks like a damn 4x4. If I could do it all over again, i'd do suspension first and wheels/tires second.
adreano17
09-29-2015 08:48 AM
