Enkei Raijins ordered. What tires?
I have a 2010 TSX V6 which came with 235/45/18 tires. I just purchased 18x8 Enkei Raijins with 40 offset. I'm currently at stock height and plan to stay that way. Is there any reason I should buy any size other than 235/45/18 again?
Also, any tire recommendations? I have always used Continental DWS in the past but am open to suggestions.
Thanks guy!
Thanks guy!
Not too sure on tire size. I got myself a set of Michelin Pilot Sport A/S 3+ in OEM 17's and they are better than the OEM tires. I am from Seattle and we have a bit of rain here and I didn't feel that confidence driving through the rain on those OEM tires. Granted I had my tires for less than 200 miles and it rained a few nights ago, I feel way more confidence driving on the Michelin Pilot Sport A/S 3+.
https://acurazine.com/forums/2g-tsx-.../#post15959327
Like, comment and subscribe
xtcnrice (02-15-2017)
^use a tire calculator.
input stock specs...then input proposed specs.
the calculator will spit out measurements and will compare it to the stock rolling diameter...
if the tire is too big, the calculator will warn you.
my favorite tire calculator is...
Tire Size Calculator - Tire & Wheel Plus Sizing
but any tire calculator will work.
use it and learn. then, you wont have to ask if your tires will fit any more
justnspace (02-15-2017)
Using my 7:40AM brain/math, 235/45/18 is just under 0.5" taller than original (diameter). I'm definitely not using a tire size calculator...but...
25.85" original 225/50/17 vs 26.32" for 235/45/18.
225/45/18 is slightly taller than stock at 25.97". But that's almost dead on. Making 225/45/18 the most appropriate size, both for 8" wheels, and diameter as compared to stock
I use 245/40/18 on my 18x8.5's. Slightly shorter than stock @ 25.71".
I use;
[(((width×aspect ratio)X2)/25.4)] + wheel size.
well...this makes TWO times in my life when I've ever made a mistake.
I didn't look closely enough at the 1st post or note that it was a V6.
i have a v6 tsx and when i ordered a set of tires through tirerack, they sent me the wrong size. 225/45/18 instead of the 235. I didnt notice until the tireshop was performing the mounting and balancing and i ended up just going with the 225. They stretched slightly on the stock wheels and the wheel gap was definitely more pronounced.
I just put some wheels on my car and went back to 235/45/18 and I dont want to go back to 225. The handling and overall steering feel is much better compared to the 225. Stick to the oem size unless you are trying to fit some crazy wheel width etc.
Good luck.
Good luck.
Good luck.
Good luck.
