Coilover and Wheel Fitment Help Needed
Hi everyone! I just picked up a 2012 TSX. I was browsing through the forums and tried to get a better understanding of what works well. After doing some reading, I still have some questions on suspension and wheel fitment. Can I run 19x9.5 +43 front, 19x9.5 +30 rear without fender mods? If not, what would fit without rubbing? Because I'm leasing the car, I am hesitant in rolling the fenders. Also, from what I've seen the Tein Basic or Megan coilovers would provide a comfortable enough ride and not cost me an arm and a leg. I don't expect stock ride comfort but I don't want to be cringing when driving over slight bumps in the road.
Any input is greatly appreciated.
there is one member defcon that is running 9.5 +45 all around and he said that the front is flush but the back he could run 10mm spacer to make it more flush he is dropped on tein spring which i belive is 1.6 front and 1.4 rear
spongebill (11-01-2011)
As Tobwac mentioned, defcon is 9.5 +45 all round but I think he is planning on putting spacers in the rears - 15mm if I remember correctly? He doesn't done any work to the guards/fenders so I think you should be fine with 19x9.5 +30 in the rears. Also, fronts should be good to go too as defcon says his are fine.
nanos
11-12-2015 08:41 PM
nuldabz
09-03-2015 05:49 PM
