Trunk lid won't open!!!
Old Feb 11, 2011 | 10:11 AM
UBNVUSE's Avatar
Since the winter season started my trunk lid wont open from the inside button and trunk button it only opens from my key remote open button. Any ideas?
Old Feb 11, 2011 | 10:51 AM
09TSXTech's Avatar
Check the trunk main switch in the glove box. It's located on the left hand side when you open the glove box.
With the main switch switch off (down position), it will disable the trunk release button on the driver's door and the trunk release switch on the trunk lid. You do that when you give the valet key to someone parking your car (with the glove box locked), they will not be able to access your trunk.
Old Mar 15, 2011 | 08:46 AM
UBNVUSE's Avatar
Thanks for the info. I will do that when i get home.
Old Jul 5, 2011 | 03:42 AM
ed_423's Avatar
SeeYou2Crew #2
bump for this. happened to me tonight, its a bit now so will try it in the morning. thank's tech for the info, my initial thought was a burnt fuse
Old Aug 31, 2011 | 11:40 AM
PO_TSX19's Avatar
Thanks so much for then info. I was expecting it to be really difficult but was pretty easy, again thank you.
Old Aug 31, 2011 | 01:19 PM
saucy's Avatar
When this happened to me, I only had the car for a few days. I was so pissed, when I found that switch. I said seriously, that was it. All I could do was laugh at that point.
Old Nov 5, 2023 | 09:07 AM
slowstonee's Avatar
If your switch is missing like mine was and you just want a quick fix: remove the glovebox, find the connector intended for the switch, loop a wire or anything conductive from one side of the connector to the other.
This completes the circuit and enables your buttons to work. May not be the "correct" way but works while you wait for the part or just dont feel like buying a new one!
SidhuSaaB
May 30, 2020 12:40 AM
Aug 15, 2019 12:58 PM
BoricuaTL
Apr 8, 2016 01:08 PM
VA2000TL
Oct 2, 2015 08:26 AM
Sep 21, 2015 08:44 AM
