Many people have had oil consumption issues
Few people would go to dealer monthly get oil level checked and eventually got new motors If you search you will find plenty of threads here and in canada with that problem You need to find a new dealer before warranty runs out |
My last oil change was with them when they topped it off after fixing the oil leak last month. I'm dropping it off again in a few hours and I asked them if they can use that as a basis for the oil consumption test. He tried to talk his way around it, but I insisted that it's what they would do anyways. Really trying to cover myself here. Don't want them to stall until it's out of warranty like you said.
The (industry) standard is that a quart of oil every 1000 miles is "normal".
I've not had any of my cars burn oil so I don't really think that a quart every 1k is "normal" but that IS the standard. Low oil after 750 miles seems more than a quart. While you should get a new dealer t look at the problem, make sure that it is well documented by the dealer before your warranty runs out. In that case it will be covered even if the repair comes AFTER the warranty expires - although it is obviously less of a hassle to get it fixed well within warranty. |
Thanks ceb. Yeah in the past the low oil warning MIGHT come on right at or past 3k miles between oil changes. This one is under 1k. The dealer said the light comes on if the oil is anywhere from .5 to 1 qt low. Just in my experience, that seems to be totally not true.
Do you find the low oil warning to be reliable in Acuras? Is there a certain threshold where it's activated? Thanks again. |
If dealer gives you run around get the regional manager involved
Update: They just called and said they have no record of changing or topping off the oil when they fixed a leak last time so they can't use that as a basis for the oil consumption check. There is nothing in the service records they claim. I specifically remember them saying any time they find an oil leak they also fill the oil. They even gave me a sticker in my window!!
Basically, I have to start a new oil consumption test with them so they have it on record in case there is a repair or issue that requires CPO warranty coverage. |
These dealers are winners
Good luck |
Originally Posted by zacharya15
(Post 15406254)
Basically, I have to start a new oil consumption test with them so they have it on record in case there is a repair or issue that requires CPO warranty coverage. Pick up the phone and call Acura corporate and open a case. That dealership is clearly staffed by a variety of people whose description you find in my signature block. Dealing with them is useless because they think you are one of them. |
(Post 15405485)
