Car won’t start, mechanic can’t figure it out
Old 01-09-2018, 07:22 AM
3rd Gear
KimAcuraTSX2013's Avatar
Acura TSX ‘13, base. Last owner replaced one of the fog lights.
Very very difficult lately to get the car to start. No clicks when turning the key, instead it cranks, stutters, tries to start but doesn’t. After trying 5-8 times finally it does start. I try for 3-5 seconds each time and wait a little in between each try. Other than this the car runs perfectly. Can’t hear anything wrong with the engine.
Everything on the dash works. Headlights come on, with maybe a 1 second delay. Doors open.
Battery is fine, alternator is fine, starter is fine. Car is throwing no codes. Mechanic is stumped. He kept the car overnight to try to diagnose it in the morning (i told him cold starts are worse, if i get the car started then shut it off, it starts easier the second time). Mechanic claims car starts perfectly every time so i told him to leave it for 8+ hours before trying again.
Anyone has has any ideas? Thanks
Old 01-09-2018, 07:49 AM
Received 16,260 Likes on 11,971 Posts
air, fuel, spark.
it's not getting enough of one of these.
air - I would check for vacuum leaks, clogged valves, etc.
fuel - maybe injectors are fouled, maybe fuel pump is done, etc.
spark - check coilpacks and spark plugs
KimAcuraTSX2013 (01-09-2018)
Old 01-09-2018, 09:10 AM
TexasHonda's Avatar
Suggest listening for fuel pump to turn on when keyswitch is turned to On. It should turn on and run for 3 secs and go off. You may need someone to listen at the gas fill w/ gas cap removed to confirm presence or absence of pump action.
If pump sound is missing or intermittent, check the main fuel relays (2) for faults before condemning pump.
good luck
Old 01-09-2018, 09:50 AM
Received 8,568 Likes on 6,621 Posts
1. GEt a new mechanic.
How did you/he check those?
My guess is on battery or starter
justnspace (01-09-2018)
Old 01-09-2018, 10:33 AM
3rd Gear
Thank you. You were right. I don't know how he checked it originally but both mechanic and AutoZone said battery was fine. Now when he left the car overnight it wouldn't start in the morning, they had to jump it - now mechanic is saying it was in fact a weak battery - quote "I'm 100% positive". I'm in Dallas and it's been cold lately, not sure if that affects it. He's replacing for $130, 2,5 year warranty, labor included.
Old 01-09-2018, 10:37 AM
Temperature definitely affects batteries. If it was on the way out, the cold temps exacerbated the issues.
Old 01-09-2018, 11:06 AM
if it was the OEM battery; you got a lot of life out of it!!
I'm In Houston and my batteries tend to only last 3-4 years.
henrychan718
10-03-2009 01:17 PM
honduh chicken
05-27-2009 11:24 AM
amsmk
11-06-2006 10:42 PM
Quick Reply: Car won’t start, mechanic can’t figure it out
