Brake Caliper Failure
Old 08-28-2016, 07:56 PM
TexasHonda's Avatar
I experienced a brake caliper failure this past week. RF Caliper was seizing and binding the brake causing a right pull and shuddering through brake pedal.
Today I removed and replaced RF caliper w/ a Napa rebuilt part ($60). I noticed the dust boot for the piston had a damaged section. I used air pressure to eject the piston and found corrosion on the piston, caliper, and caliper seal (rust particles).
I failed to inspect the dust boots on the calipers when I replaced the brake pads in late 2015.
Piston was pitted and plated w/ rust corrosion. This occurred in S Texas w/ no salt on the roads.
Lesson learned is to carefully inspect the caliper piston dust boots when replacing brake pads.
Good Luck
xtcnrice (08-29-2016)
Old 08-29-2016, 08:52 AM
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
thanks OP for the update!
95oRANGEcRUSH
01-07-2024 07:05 PM
MGK
08-10-2016 07:38 PM
Skirmich
1/2G MDX (2001-2013)
08-03-2016 02:11 PM
Acuraneewb
03-07-2016 01:50 PM
rocket_pup
01-13-2016 02:10 PM
Quick Reply: Brake Caliper Failure
