Air conditioning condensate??
I am getting water on the passenger side floor. I suspect it is the A/C condensate leaking into the cabin. Wondering if anyone else has had this problem... Any recommendations or pics showing where the condensate hose breaks through the firewall?
-mark
-mark
A/C Water on passenger side
2009 TSX Tech/Package
I have exactly the same problem with my car. First, I had a bad smell that came out from the a/c vents inside the car. They cleaned the system and now water leaking on the passenger side. I have taken the car twice to the dealership for this reason. First, they found that with the a/c on, there is a slight bit of moisture seeping through the evaporator access door seam and they found a seal that was shifted. On the second visit, they found that the condensation on heater line was caused when the vehicle reaches low temps. But I'm still with the same problem. Also, i have noticed that the a/c hose inside the engine has a lot of water bubbles and it looks like frozen. Since, we have the same problem, I'll let you know if they finally can find the source of the problem or if you have luck I will apreciatte some help. Thanks.
SidhuSaaB
05-30-2020 12:40 AM
Biggie_B
02-26-2017 11:14 AM
rcs86
08-02-2016 06:52 PM
lanechanger
10-13-2015 10:56 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
ac, acura, air, car, condensate, condensation, conditioning, leaking, mdx, passenger, problem, side, tsx, vents, water
