SiiRBrooklyn's Progress
#82
Been a while, no new updates still haven't installed my rear camber kit but hopefully i will soon. I will be attending Simply Clean 6 in daytona, FL also ive gotten accepted into Wekfest Miami YEEEEE LOL... In the mean time here's afew pictures from a photoshoot some weeks ago.
Follow my IG @i_CU2
Follow my IG @i_CU2
SiiRBrooklyn (11-19-2014)
#86
BF4 player? good man
#90
OOOOOhhhh snapppppp, i was thinking about sellling the 3g, and buy something different....... This is making the decision so much easier!
loooookkkkkiiinnnggggg gggoooodddddddddddd
#93
Update on the whip... got the front sports bumper and euro grille. Put the rear H emblem on and the rear is currently sitting at -10 camber tucking abit.
#95
takin care of Business in
Received 4,732 Likes
oomph
SiiRBrooklyn (06-16-2015)
#101
damn!
am not a huge fan of stance, but I certainly appreciate the amount of work and effort you have put into it...looks awesome!
#103
did you not trim your bumper to get rid of rubbing? I did to stock bumper so i assume you would have to for this too. oh and btw i rubbed off the screw hole so I dont have screws holding the bumper at the wells lol
#105
Don't believe that im rubbing lol. 18k springs in the rear, suspension set at 30 clicks stiff so i don't have much movement going on. And my screws are on lol. Anyway i wouldn't want to cut a $700 bumper lol
#107
Been awhile, just missing sideskirts still but soon coming. I've bought RL calipers and will be doing the conversion. I bought EBC slotted rotors and Red Stuff brakes and painted the calipers with high heat caliper paint thats good for upto 900 degrees. Hopefully mounting them on next week or so.. just waiting on brackets from fatfour also i have sold my wheels and have ordered some 3 piece Rotiforms. Should be getting those within another 2-4 weeks i think. Doing more but thats it for now.
..Follow me on the gram @Killao_
#110
Update: Tinted the front windshield 20%. Looks good but vision isnt 100% at night lol ill post a picture later. Also copped a new grille for just $200 only thing wrong was a tiny paint chip and two tabs were broken off but ill be fine. And just waiting on my brackets to come in to start the RL conversion.
#111
Got the FatFourCustoms bracket. Didnt like how they were shipped. Pretty much just thrown in a box. But thats me im picky lol. Installing tomarrow hopefully just gotta get some brake fluid.
#112
Was quick except for when i stripped my rotor screws. Cut off the shield takes nothing if you dont have a grinder a flat head screw driver and hammer will cut it. Added 20mm spacers but have a gap pretty sure 15mm wouldve worked good. No big difference but its somewhat smoother and well appearance wise its a plus lol.. Also recieved my grille swapped that on real quick just 5 minutes. ...Peep the front 20% windshield
#114
Gonna order side skirts this week or next and want to get puddle lights just waiting on a shop to restock on those again. And also have a messed up quater panel from when i used to poke on the rear hopefully getting that fixed this month or next. By then i should have my wheels. After that im looking to make camber in the front so i might get my lower or upper arms shortened or extended.I know i can get megan uppers but i dont think I'll have the camber i want i think i heard megan uppers only make upto like 4-5 im looking for 5-8 but we'll see
#116
Yeah its good. Rides smooth even with my 18k rear springs but of course on bumpy roads not much fun lol. Im gonna be upgrading my front springs to a higher rate just not sure to which yet. Im debating between 20-30k
#117
Little update.. got my side skirts in from Acura and also scooped up a K&N Intake that came with a free recharge kit.. excited to push out +3HP more . Wheels are being finished up and should be receiving them within a week or two im hopeing. Also thinking about ordering upper control arms from T-Demand. They say it maxes out at -30mm which i was told was around 5 to 8 degrees of negative camber but idk yet cause they want an arm and d**k lol. And wanted to let you guys know that the RL Calipers with EBC Redstuff brake pads are great and i now do feel a difference since i bled all calipers multiple times. Only thing i don't like about the pads are that they squeak and they are not "low dust" as EBC states they are but other than that they're good. Also i don't know who runs 12.8" rotor but im running 12.6" and the calipers are real close to touching the rim. Just an FYI but then again its only .2 of an inch so maybe you'll be fine if you do run them that big.
#118
Forgot to add i bought a 12" Orion 4000 watt sub. Shits about to get real lol but thats something for later this year. I need thicker cables and a bigger amp (money on more money)
#119
How much and where did you get your side skirts from?
#120
VTEC just kicked in, yo!
Nice update. Yep the Redstuffs are definitely not "low dust" as they claim. I've gotten a replacement set from EBC as they admitted my first set should be defective, but nope, second set were just as squeaky/dusty as the first.
I assume you're the type to want to keep your wheels fresh/clean. I recommend you switching out to a different set of pads, unless you plan on wiping the wheels down every night. If you leave the dust on for a while, the dust could effectively stain/etch your wheels. I ordered a set of Akebono Pro ACT pads... hopefully I'll get a chance to install them sometime next month.
Oh and I have the 12.8" rotors. I had thought the squealing/dusting might've been related to that, but I'm about 90% sure it's completely due to the pads.
