Julius' Airrunner for 2009-2014 Acura TSX
Old 02-27-2018, 09:30 PM
  #161
julius071's Avatar
Getting close to able to mount these bad boys but need to install all other suspension parts. Had the wheels coated over at Mr. Detail in Seattle, Ballard, WA to be exact. Hit up Mike with all your detailing needs. Mr. Detail Seattle - The Best Car Wash & Auto Detail
Old 02-27-2018, 10:23 PM
  #162
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
Nice... and please tell me those CEs are yours as well
Old 02-28-2018, 12:32 AM
  #163
julius071's Avatar
Thanks and no those are not my CEs. Another customer dropped off their wheels to get coated when I picked up the wheels.
Old 03-11-2018, 10:15 PM
  #164
julius071's Avatar
Been reading about Honda OEM TPMS with SSR wheels and how it is not compatible so I had to find out myself and OEM TPMS does fit with SSR CV04.
Here is Honda OEM TPMS into SSR CV04. Its a bit short so I ordered SSR valve stem extension (see photo below)
Here is with SSR valve stem extension:
Does any one know if the Honda OEM TPMS needs to be flush with the barrel or can it be free floating but held tight to the barrel with the Honda OEM TPMS locking nut like here:
Old 03-12-2018, 04:35 PM
  #165
xtcnrice's Avatar
Does not need to be flush. Mine are strapped to the barrel itself, very far away from the actual valve stem. Your usage of the SSR extension is probably the most ideal option for your situation.
julius071 (03-12-2018)
Old 03-12-2018, 04:51 PM
  #166
julius071's Avatar
Thanks for the feedback! Want everything to be prepared before I bring the wheels and tires down to the shop to get mounted and balanced.
xtcnrice (03-14-2018)
Old 03-29-2018, 12:15 PM
  #167
julius071's Avatar
Special Edition Headliner Conversion
This is a long time coming, special edition black headliner conversion. Spent about a fraction (including installation which involves removing the rear windshield) if everything was bought from factory.
xtcnrice (03-31-2018)
Old 03-31-2018, 04:09 PM
  #168
xtcnrice's Avatar
niiiiiiiceeeeeeeeeeee! I've always wanted to do this. Great work!
Old 06-04-2018, 01:40 AM
  #169
apexbryle's Avatar
Looks good with the black headliner! Hope to see it in person soon bro.
julius071 (06-04-2018)
Old 06-04-2018, 09:06 AM
  #170
julius071's Avatar
Gone do some bbq once its warmer out and I'll let you know for sure. Did you install all your goodies?
Old 06-18-2018, 01:28 AM
  #171
apexbryle's Avatar
You'll see soon hopefully!
Question, the service manual for removing the headliner says you can disassemble the front cabin area and have enough clearance to remove the headliner through the front doors, assembly the same way. Who did you go to for removing the rear glass?
Old 06-18-2018, 09:38 AM
  #172
julius071's Avatar
I had Durham Upholstery https://www.durhamuph.com/ do the conversion and they had their "glass guy" remove the rear glass.
Old 02-14-2020, 04:06 AM
  #173
julius071's Avatar
Is it time to install the t-demand parts and maybe mount the wheels?! Vlog included!
Old 02-14-2020, 06:44 PM
  #174
julius071's Avatar
Video is now live!
Old 02-29-2020, 02:59 PM
  #175
julius071's Avatar
Uploaded a new video on how the car sits!
Old 07-23-2020, 07:15 PM
  #176
julius071's Avatar
After a very long time, finally test fitted the wheels!
Old 07-24-2020, 06:50 AM
  #177
k_dot's Avatar
Quite a build you have going on! Did you use a plug and play harness for the JDM/EDM bi-xenons? If so where did you get them?
Old 08-08-2020, 04:40 PM
  #178
julius071's Avatar
Thank you! Yeah i used the plug and play harness from here Ratchet Racing. Got the "Ratchet" option with "Flash to Pass" Simple install with color picture instructions.
Old 08-21-2020, 07:50 PM
  #179
k_dot's Avatar
That's great news. I'd love to get these headlights down the road and not make any major modifications for functionality.
julius071 (10-07-2020)
Old 10-07-2020, 07:30 PM
  #180
julius071's Avatar
I checked the vendor where I got my headlights and they raised the prices
Old 10-07-2020, 07:32 PM
  #181
julius071's Avatar
Installed new battery for the TSX and mounted tires on the wheels!
UA7X
10-08-2020 05:36 PM
kvan2007
03-21-2011 11:25 AM
T-R
09-22-2004 12:40 PM
Crazytree
01-06-2004 10:33 AM
Zapata
10-28-2002 10:07 AM
Quick Reply: Julius' Airrunner for 2009-2014 Acura TSX
