Jo's Wagon intro and build!! - Page 3 - AcuraZine - Acura Enthusiast Community
Notices
Old 11-19-2018, 02:30 PM
  #81
Registered Member
Nice build! Those are some impressive numbers!
I was planning for a supercharger as well but since it's discontinued, it is difficult to find even used one. Do you think Merc supercharger will fit without too much of modifications? has anyone done it for TSX? Does it come with a tune as CT-E does? at least to get the car running. I am just skeptical to buy at this point as too many unknowns.
ksawant is offline
Old 11-19-2018, 02:49 PM
  #82
Registered Member
Originally Posted by jobata23 View Post
1. I did a dyno tune on a Mustang Dyno and the CTe base map doesn’t come close to the power I got and
2. I believe the Merc supercharger is probably 90% bolt on kit because my CTE kit is not 100% and I had to modify a few things on the engine coolant piping to make it work and when I upgrade to Merc I will use their supplied parts because Merc has a different Manifold setup and also my kit was preowned.
Could you explain to me what is needed to get the tuning portion of the install done? Did your kit come with a base map on a piggyback (Hondata or FlashPro) to get it moving and then your tuner was able to retune that piggyback?
I find the hardware part as a doable challenge but when it comes to software, I am way over my head.
You and I both. I believe Heeltoe can still get the CtE kit but they don't have too many left.
Also, I am looking more for reliable drivability than making a lot power. Too bad NV doesn't get too cold, I wonder how the SC will behave in the extreme winter.
Sheefo2k is offline
Old 11-19-2018, 08:36 PM
  #83
Registered Member
I already asked a question on their product page about the availability of sc kit but a response was generic(as discontinued). I am thinking of sending an email or calling Markus directly to see if he can do anything. I am also mainly looking for a daily drivability and reliability as this is the only car I have. I will update you if I get an update on the SC availability.
ksawant is offline
Old 11-20-2018, 02:32 AM
  #84
Sin City
I think the Merc supercharger will fit but not 100%, and I don't think there is a base map for the Merc Supercharger and I think the base map for the CTe will work just fine, You just have to make sure get a tune asap. What I did to my car, before installing the SC and since there is no base map for the wagon, I converted the 2010 base map Supercharger file to the 2012 calibration. Then After installing the SC I uploaded the file and the car started and the next day I drove it to my tuner and I stayed out of boost which is below 2500rmp I believe, and from there you tuner will handle the rest.
Sup man, no base map for the Wagon but you can convert the file from 2010 files to 2012 calibrations, which I did and make sure to change fuel injector size in Hondata Flashpro calibration to the size you will be using. The car should start and after drive to your tuner and stay out of boost and the your tuner will take care of the rest. Also I ran into issues installing the SC because there was an extra coolant tube attached to the main coolant line and without me modifying the coolant line the manifold will not fit to the head. If you ever tackle this by yourself, just PM me and I can help you out
jobata23 is offline
The Following 2 Users Say Thank You to jobata23 For This Useful Post:
ksawant (11-20-2018), Sheefo2k (11-20-2018)
Old 11-20-2018, 10:27 AM
  #85
Registered Member
You're the man. Could you get us some videos whenever you get some time?
Sheefo2k is offline
Old 11-20-2018, 01:16 PM
  #86
Sin City
I'll try to, but is there any place beside youtube I can upload videos without the whole world seeing it ?
jobata23 is offline
Old 12-07-2018, 02:29 AM
  #87
Sin City
I finally replaced the factory Battery with a better one and went with Optima Red 35 series with A V6 battery strap. Also after replacing the old battery with the Red Top, My Bluetooth stop disconnecting from my Iphone.
jobata23 is offline
Old 12-07-2018, 04:22 AM
  #88
WTF?
Midnight Mystery's Avatar
cu2wagon Thread copywrite.
Midnight Mystery is offline
Old 12-07-2018, 08:31 AM
  #89
Registered Member
Team OptimaRedTop is the way to go. Without a doubt my audio sounds much better after installing the new battery as well. Secret little mod.
Sheefo2k is offline
Old 01-12-2019, 04:41 PM
  #90
Sin City
Starting the New Year right! New Summer wheels and the most important Aftercooler and Smaller pulley!
jobata23 is offline
Old 01-14-2019, 01:23 PM
  #91
Registered Member
julius071's Avatar
Wheels are fire!
julius071 is offline
Old 02-05-2019, 08:32 PM
  #92
Sin City
Recent pics before stage2 and new wheels
jobata23 is offline
Old 02-12-2019, 07:12 PM
  #93
Registered Member
2012wagon's Avatar
What are new wheel specs?
You said exhaust is sedan only but fit bolt on perfect? Link to exhaust? Any drones?
2012wagon is offline
Old 02-14-2019, 01:25 PM
  #94
CCColtsicehockey's Avatar
Your wagon looks great. The JDM rear end really made a world of difference. Looks much more like a proper wagon from the back.
CCColtsicehockey is offline
Old 02-15-2019, 03:12 AM
  #95
Sin City
The specs are 18x9.5 40 offset and the exhaust is made for the sedan and it will fit the wagons as well, also it drones a little bit but just because I'm running cat-less and also remember the wagon has an open rear cargo unlike the sedan's is completely enclosed by the back seats.
Thanks man, the rear JDM conversion does make a big difference in looks and how it flows with the rest of the body
jobata23 is offline
Old 02-15-2019, 11:14 AM
  #96
Registered Member
2012wagon's Avatar
Thank you. So didn't need any modifications for install?
MrHeeltoe please confirm, before we order from you
Old 02-15-2019, 11:25 AM
  #97
Platinum Sponsor
MrHeeltoe's Avatar
This is correct, sedan and wagon exhaust for the system fit exactly the same.
MrHeeltoe is offline
Old 02-15-2019, 03:56 PM
  #98
Sin City
No modification needed
jobata23 is offline
Old 02-15-2019, 06:58 PM
  #99
Registered Member
2012wagon's Avatar
Thanks guys
time to order
Old 02-18-2019, 02:42 PM
  #100
Sin City
Aftercooler install and pulley
jobata23 is offline
The Following User Says Thank You to jobata23 For This Useful Post:
julius071 (02-19-2019)
Old 02-19-2019, 06:50 AM
  #101
Looking good.
All your regular mechanics tools and hey a kitchen knife too
Old 02-19-2019, 10:27 AM
  #102
Registered Member
julius071's Avatar
Very nice!
Old 02-19-2019, 10:58 AM
  #103
Registered Member
dhuynh's Avatar
Duck me... loving the progress man!
dhuynh is offline
The Following User Says Thank You to dhuynh For This Useful Post:
Sheefo2k (02-26-2019)
Old 02-20-2019, 03:11 AM
  #104
Sin City
Looking good.
Thanks and hehe.. good catch! I had no hose cutter for the heat exchanger, so I had to improvise
Originally Posted by julius071 View Post
Very nice!
thank you!
thanks for the love man, my next project will be a manual conversion
jobata23 is offline
Old 02-20-2019, 03:18 AM
  #105
Sin City
A tune after the Install
A quick pic after the tune
jobata23 is offline
CCColtsicehockey (02-20-2019)
Old 02-20-2019, 10:21 AM
  #106
Registered Member
julius071's Avatar
All pics and no video?
Old 02-20-2019, 03:22 PM
  #107
A manual swap next
I can tell you one thing. Having had that done that on my first gen TSX it is not a fun process at all. The shop said no more after that haha.
The Following User Says Thank You to CCColtsicehockey For This Useful Post:
MrHeeltoe (02-20-2019)
Old 02-20-2019, 04:46 PM
  #108
Sin City
Sorry but Check out my [email protected]_dailyscwagon23 for vids, sorry I donít want to post in youtube
A manual swap next
I know a master mechanic and who specializes on kseries and tuned my car, he will gladly do it, since he has done it many times
jobata23 is offline
Old 02-20-2019, 05:17 PM
  #109
Sin City
My latest dyno
jobata23 is offline
Old 02-20-2019, 05:43 PM
  #110
Platinum Sponsor
MrHeeltoe's Avatar
A manual swap next
I have a customer that did a manual swap in a TSX wagon. It was a job for sure...but enviable result!!!
__________________
Heeltoe Automotive: In Your Corner since 2002
One Stop Honda/Acura Sports Shop
Visit Heeltoeauto.com Today!
Got a question in a thread? Tag @@MrHeeltoe
Call or Text 949-295-1668 for help or advice
"From show to go, street to track, apex to exit, and to work and back...Heeltoe's in your corner!" - Marcus
Old 02-20-2019, 11:10 PM
  #111
Registered Member
2012wagon's Avatar
Waiting to see the new wheeels
Old 02-21-2019, 01:09 AM
  #112
Sin City
Not until summer
jobata23 is offline
Old 02-21-2019, 08:12 AM
  #113
Indeed a supercharged manual wagon would be an awesome ride for sure.
Old 02-23-2019, 10:14 PM
  #114
Platinum Sponsor
MrHeeltoe's Avatar
He was going to go with a Merc TVS blower but I think he bailed on that.
Some other guy in Florida did a J37 6MT AWD conversion in a wagon! That was nuts.
Old 02-25-2019, 08:26 AM
  #115
Not to take this thread too off topic but you have any links to that J37 AWD conversion if there is a thread? I would love to see that.
Old 02-25-2019, 01:44 PM
  #116
Sin City
He is in our CU2SQUAD in facebook and Ig https://instagram.com/phillira28?utm...=1l4k66drm3w2s
jobata23 is offline
Old 02-25-2019, 01:46 PM
  #117
Sin City
My last mod before the summer heat 🤭
jobata23 is offline
Old 02-26-2019, 09:32 PM
  #118
Registered Member
Added ya!
Great work as always. Cleanest I have ever seen.
Sheefo2k is offline
Old 02-27-2019, 02:47 PM
  #119
Sin City
Sup man, yeah I thought that was you who requested me on IG, how is the wagon?
jobata23 is offline
Old 02-27-2019, 04:47 PM
  #120
Registered Member
Lol smart man. Not much on the daily wagon yet but I did buy a E63 AMG.
Sheefo2k is offline
