brotatertot's 09' (Steel Mustache) TSX
The grille looks like a mustache to me. Picked it up with 72k on the clock, it had bad piston rings, so the dealer swapped them out under a TSB. So I was off to a super decent start..
https://cimg4.ibsrv.net/gimg/acurazi...ce567cf7c4.jpg Had the windows tinted & picked up some f&f coilovers https://cimg6.ibsrv.net/gimg/acurazi...2230a90ccf.jpg Put a K&N intake & a Spirior grille on, switched out all the other badges too. https://cimg7.ibsrv.net/gimg/acurazi...be8f6c323f.jpg Then I found a Modulo bumper that needed to be fixed, so I had a buddy fix & paint it. https://cimg2.ibsrv.net/gimg/acurazi...2e4707df9a.jpg Picked up trashed evo 8 wheels (favorite factory wheel) & refinished them & had new decals made. https://cimg8.ibsrv.net/gimg/acurazi...b27a2e3f88.png https://cimg7.ibsrv.net/gimg/acurazi...ccb90b5419.jpg https://cimg1.ibsrv.net/gimg/acurazi...a74abe2ba4.png Found a beat up VIS carbon trunk I repaired, then had a buddy re-clear it. https://cimg0.ibsrv.net/gimg/acurazi...e627430ca8.png https://cimg3.ibsrv.net/gimg/acurazi...304dee66d1.png https://cimg6.ibsrv.net/gimg/acurazi...a7da047657.jpg |
Great start!
wheels are a little sunken in....would love to see a better fitting wheel there! |
(Post 16144447)
Great start!
car looks great! planning on getting the CF hood to "match"?
Originally Posted by xtcnrice
(Post 16144594)
That grill looks way better.
Originally Posted by brotatertot
(Post 16144466)
Thanks! It might be because of the rear not having any camber adjustment yet,(need to fix that soon) this car also sees a bit more spirited driving than most daily drivers, so I wouldn't want the wheels to ever come in contact with the body with as much as I throw it into corners. They did once in front, then I lifted it a bit, the newer front bumper doesn't help on steep inclines either lol.
What are the specs on the wheels? Great progress, great projects, great work!! |
(Post 16144594)
(Post 16144973)
you could always raise it up a bit! even 5mm up will prevent it from coming in contact.
I hit the 120k mile mark, so I figured I'd change the plugs & change the manual trans for the 2nd time.
https://cimg2.ibsrv.net/gimg/acurazi...edc595dabc.jpg https://cimg5.ibsrv.net/gimg/acurazi...001e0c5b1b.jpg Plugs were pretty much toast https://cimg4.ibsrv.net/gimg/acurazi...93cafbde21.jpg https://cimg5.ibsrv.net/gimg/acurazi...9dafe319d4.jpg One thing that has me confused, is more trans fluid came out than went back in. 2qt came out when I drained it, but it started spilling back out of the fill hole after 1.5qt. The last time I changed the fluid this didn't happen. Anyone else experience this before? |
I put in some yellow fog lights, they helped out more than I thought they would.
https://cimg0.ibsrv.net/gimg/acurazi...15ed1c7dfb.jpg https://cimg4.ibsrv.net/gimg/acurazi...1403cd8e40.jpg https://cimg8.ibsrv.net/gimg/acurazi...690106d5b0.jpg My carbon trunk wont allow the factory license plate lenses to be installed, due to it's increased thickness in that area. Since they have to be glued in place (like my back up camera), I bought some LED's to destroy instead of my factory lenses. https://cimg1.ibsrv.net/gimg/acurazi...8b8756a11e.jpg https://cimg9.ibsrv.net/gimg/acurazi...1873d2c7c4.jpg |
Where can I the Carbon Trunk lid?
Looks great! Thank you for sharing that information on the truck lid.
Originally Posted by julius071
(Post 16201654)
Finally found a decent deal on an SE black woodgrain center section. I need to wax the scuffs out, none of them are deep, but it bugs me.. https://cimg8.ibsrv.net/gimg/acurazi...dc83006132.jpg Also threw on my Buddy Club queball, feels a lot better than the factory knob. The sunflare in this pic was unintended, but super neato.. https://cimg2.ibsrv.net/gimg/acurazi...28c203fe30.jpg |
I took advantage of the nice weather over the weekend here in MO and installed my sport pedal set. What a pain in the dick! Multiple trips to O'Reilly's & multiple sub-par riveting tools were to blame, but it got finished.
https://cimg2.ibsrv.net/gimg/acurazi...9fd25744d8.jpg https://cimg6.ibsrv.net/gimg/acurazi...8e99f6976d.jpg https://cimg1.ibsrv.net/gimg/acurazi...0c6a40b5b0.jpg |
When did you get the car? Looks like Dec of 17 at 74k miles and now its a little over 4 months later with 120k on the clock. Thats a lot of driving!!!
Looks good doe! |
Looks great! What else you got plans for this Mustang
Originally Posted by BreezyTL
(Post 16213713)
Looks good doe!
(Post 16213801)
(Post 16213865)
Car was purchased on Oct 23, 2014. I just hadn't been on the forums in a few years. That's why the wording in the 1st post was all past tense, sorry for the confusion. Thank you!
Wrong forum bro |
My brother hooked me up with a factory trunk mat, had to clean it up first.
https://cimg2.ibsrv.net/gimg/acurazi...9fd8a9b9b5.jpg https://cimg7.ibsrv.net/gimg/acurazi...a42505490b.jpg |
A stick holding up your carbon fiber trunk, why?
Maybe no tension spring because it'd be too strong and would fling the trunk open when it's popped?
That had better be a CF rod though. |
Originally Posted by cu2wagon
(Post 16216902)
I installed a spoiler on our 2003 Accord and I seem to recall that there was either a new spring needed that was stronger, or there was a little doohicky that was installed to increase the spring force so the trunk would open (opposite problem of yours). I wonder if there's a spring from some other vehicle in the Honda catalog that would work.
Or really, if you just take the stock spring and clamp one end in a vise, you should be able to twist out some of the preload so it's a lighter force. |
(Post 16216982)
This car has been put through the ringer lately, a hail storm decided to thrash it a little bit, and upon moving it to my carport out back, the neighbors' tree decided to give it a big hug. Sad thing is their homeowners insurance did not cover it, I had to file it under my comprehensive & pay my deductible.
https://cimg1.ibsrv.net/gimg/acurazi...1332df3159.jpg https://cimg4.ibsrv.net/gimg/acurazi...a41fd889f6.jpg https://cimg3.ibsrv.net/gimg/acurazi...ff92b54df7.jpg https://cimg7.ibsrv.net/gimg/acurazi...ac6752985e.png https://cimg9.ibsrv.net/gimg/acurazi...78610e9187.png After bouncing between here & there with State Farm, getting mixed answers & waiting 3 weeks to have an adjuster assess the damages, I was growing very tired of their funhouse mirrored puzzle basement. Fortunately for me, my friend owns a body shop & gave me a free loaner (after I found out loaner vehicles aren't covered on my plan), he & his team did the work right & saved the day, so for that I am more than thankful. $5,200 later and it now it looks even better than before all this. https://cimg4.ibsrv.net/gimg/acurazi...4fd1f2ab57.jpg |
After I got it back, I saw the headlights were in need of a restoration, so Brian & I sanded with 2500, then 3000. After that came the foam pad, 3M rubbing compound, Perfect-it, & 3 coats of wax. Turned out to be super decent.
https://cimg5.ibsrv.net/gimg/acurazi...80499a7498.jpg https://cimg3.ibsrv.net/gimg/acurazi...3e0b7a3aef.jpg https://cimg0.ibsrv.net/gimg/acurazi...fb5bfeb333.jpg https://cimg9.ibsrv.net/gimg/acurazi...a1c43fee0b.jpg https://cimg5.ibsrv.net/gimg/acurazi...6822260ff1.jpg https://cimg9.ibsrv.net/gimg/acurazi...0c0a27e5bb.jpg https://cimg9.ibsrv.net/gimg/acurazi...0681cc7ded.jpg https://cimg3.ibsrv.net/gimg/acurazi...8dc7723ce5.jpg |
all your shit is sex, bro taste her tots.
(Post 16274333)
Got around to installing my PLM header, it was a bitch to say the least, a little more pep in it's step now though.
https://cimg4.ibsrv.net/gimg/acurazi...71c3c87c05.jpg The collector end of it was tweaked about a 1/4" and would not budge, a lift was needed, because my narrow-ass & floor jack weren't cutting the mustard. https://cimg7.ibsrv.net/gimg/acurazi...0af1b513ce.jpg https://cimg0.ibsrv.net/gimg/acurazi...1101737b36.jpg All buttoned up & only a hair louder than stock, I'm a happy camper now. https://cimg8.ibsrv.net/gimg/acurazi...93dca83e03.jpg |
shit yeah, man...love that.
nice! any particular reason why you decided the PLM over RV6?
(Post 16304632)
(Post 16304676)
I've been working with carbon for a while now, here's a few things I've done to the tsx.
https://cimg1.ibsrv.net/gimg/acurazi...011cb4b1dd.png https://cimg7.ibsrv.net/gimg/acurazi...f37561d38b.png I didn't like the dimples or the ridges on the top side, so I filled them in. https://cimg3.ibsrv.net/gimg/acurazi...195418c3a7.png https://cimg6.ibsrv.net/gimg/acurazi...fe85b2b1a4.png https://cimg9.ibsrv.net/gimg/acurazi...372fa438e5.png https://cimg2.ibsrv.net/gimg/acurazi...17654b2fb8.jpg Still in the process of finishing these window switch bezels https://cimg1.ibsrv.net/gimg/acurazi...8c3abedc2a.jpg https://cimg4.ibsrv.net/gimg/acurazi...2891be8434.jpg https://cimg1.ibsrv.net/gimg/acurazi...6e42105dbe.jpg https://cimg0.ibsrv.net/gimg/acurazi...0ec8ce8025.jpg |
that's cool!!!!!!!!!! :)
