OFFICIAL Hondata Flashpro Calibration/Tuning Thread
Old Nov 24, 2015 | 05:29 PM
  #1001
ssjoeboe9's Avatar
ROTAREDOM
Originally Posted by iselfdevi
Hondata added the "Overrun throttle opening" option for you 09-10 guys. Check in the "Throttle" tab. This will get rid of rev hang.
If you end up using this option, make sure you adjust the "Overrun fuel cut delay" to about 40-50 (or lower)for a smoother throttle closing. That option is in the "Fuel" tab.
After "unchecking" Overrun throttle opening, which settings for overrun fuel cut delay have you found to be the smoothest transitioning from gear to gear? Can you post a pic?
I'd rather be lazy and use your settings lol... have you noticed a big difference? Or is drive-ability decreased with this change?
Old Nov 25, 2015 | 07:26 AM
  #1002
Username 0's Avatar
I like cars.
I put 40 for all gears. I can try to take a pic later.
It did take some getting used to but I like it this way because it now feels like I have a "throttle cable" type feel that I missed so much. My next goal is to get rid of that drive-by-wire delay. Not sure how I can do that though.
Old Nov 25, 2015 | 08:10 AM
  #1003
ssjoeboe9's Avatar
ROTAREDOM
You can do it! It's in the FP somewhere, it's actually how Honda puts its newer cars in "ECON" mode, it just limits the throttle position vs. how much ECU responds to that position.
i.e. in normal mode throttle 1/2 way down= 50% throttle
In econ mode throttle 1/2 way down= 35% throttle
**Edit-- I should also add that there is voltage delay too ( to reduce jerkiness).. so on a 5V scale throttle 1/2 way= 2.5V and 50% throttle however there is a few milisecond delay the ECU adds before it send the signal of 2.5V so there is a steady climb in acceleration instead of spinning the wheels.
Old Nov 25, 2015 | 11:56 AM
  #1004
Cu2Suspect's Avatar
Gonna try this out later today since I got a new cal from vit, currently on 2.4... Getting better every cal
Old Nov 25, 2015 | 06:17 PM
  #1005
Cu2Suspect's Avatar
Wow what a difference that made, car drives amazing now and I didn't even change any values only checked that box
Old Nov 26, 2015 | 06:44 PM
  #1006
boki_cu2's Avatar
Awaiting my next cal from vit
So exited ahha what version you guys on. Im on 0.3 lol
Old Nov 26, 2015 | 07:28 PM
  #1007
Cu2Suspect's Avatar
I started at 1.0 no clue how your on 0.3 Lol
Currently on 2.4 Id say about half way... Car runs hard and smooth
Old Nov 26, 2015 | 09:02 PM
  #1008
boki_cu2's Avatar
Well 01.3
Im awaiting a new one no response in 2 days haahha
Old Nov 27, 2015 | 07:30 AM
  #1009
Cu2Suspect's Avatar
Well 01.3
He's off for the holiday, will be back Monday I think
Old Nov 28, 2015 | 09:01 AM
  #1010
Username 0's Avatar
I like cars.
Nice! Now to get rid of that pedal delay. Rev hang was a major annoyance to me. I miss the old cable throttle days.
You should try changing the overrun to "40". It will feel even better.
Old Nov 28, 2015 | 03:34 PM
  #1011
threetwentyfizzle's Avatar
Originally Posted by iCrap
Heads up, I have a TSX FlashPro listed for sale if anyone needs one.
Hey @iCrap , if you still have your FP up for sale I'm interested. is it for the 2011+ FP? My car is a '13 S.E. Sorry been a little while since I've been on the forums, just saw the post today lol.
Sorry to hear about your car tho :/
Old Nov 28, 2015 | 11:19 PM
  #1012
iCrap's Avatar
TSX AMG Type //M i-VVT
^ Yeah i pmed you back
Old Nov 29, 2015 | 06:57 AM
  #1013
swany0095's Avatar
can I put 40 for all gears without messing anything up? i do not have to option to check the box yet, because I have an 09.
Old Nov 29, 2015 | 09:08 AM
  #1014
Cu2Suspect's Avatar
There was an update for 09-10 I have a 10 and it's there
Old Nov 29, 2015 | 09:33 AM
  #1015
PrimeTimeTSA's Avatar
could you code an ecu on a bench?
Old Nov 29, 2015 | 09:52 AM
  #1016
Jaheri_cbp's Avatar
Maybe if you are an authorized hondata pro tuner, even then I'm not sure what they are equipped with as I believe all newer car hondata products for tuning simply reflash the factory computer (no standalone). Even then what would be the purpose of bench coding the ecu? The flashpro is designed to be used through the obd2 port so you couldn't use that to bench flash the ecu.
Old Nov 29, 2015 | 09:55 AM
  #1017
I need to code an ecu to work with my swap, id like to see if I could send the ecu somewhere to get coded.
Old Nov 29, 2015 | 10:46 AM
  #1018
Jaheri_cbp's Avatar
You could try contacting hondata directly with any questions in regards to this. I believe if you send the ecu in to them they can flash it.. Recoding to work with a swap Im not sure but you do pay to have them to reflash it every time it's sent in and that's usually a basemap with certain generic setups that would correlate as closely as possible to yours. Where with flashpro you have self-tune ability.
Old Nov 29, 2015 | 12:28 PM
  #1019
iCrap's Avatar
With a swap maybe you are better off with custom ecm
Old Nov 30, 2015 | 09:59 AM
  #1020
xtcnrice's Avatar
VTEC just kicked in, yo!
yeah probably better to go with a standalone... but that shit expensive
Old Dec 4, 2015 | 08:54 AM
  #1021
Cu2Suspect's Avatar
I looked at it and have no clue on what you changed lol pretty noob when it comes to this software if you can post a pic or video whenever you get a chance of what you changed Id like to try it out
Old Dec 5, 2015 | 02:53 PM
  #1022
Username 0's Avatar
I like cars.
You can start as low as 10, then 20 and so on until you like how it drives.
The last tab "5" counts for both 5th and 6th gears.
Old Dec 5, 2015 | 03:00 PM
  #1023
ssjoeboe9's Avatar
ROTAREDOM
itty bitty injectors
Old Dec 5, 2015 | 03:07 PM
  #1024
Cu2Suspect's Avatar
Thanks gonna try this with my next calibration
Old Dec 5, 2015 | 03:15 PM
  #1025
ssjoeboe9's Avatar
ROTAREDOM
Btw.. iselfdevi suggest 40 across the board, just for reference. He said he liked this setting the most.
Old Dec 6, 2015 | 07:11 PM
  #1026
Username 0's Avatar
I like cars.
They are perfect for my setup though. Anything more would of been overkill and a waste of money.
Old Dec 12, 2015 | 05:47 AM
  #1027
Cu2Suspect's Avatar
Uploaded Cal 2.6 from vit yesterday and adjusted the values like you said... Felt like I was in my RSX like the good old days! Miss shifting like that... Thanks again
Btw still waiting on the videos!
Old Dec 13, 2015 | 08:40 AM
  #1028
Username 0's Avatar
I like cars.
Good to hear! I want to post vids but the delay caused by the drive-by-wire system bums me out. I can even rev match correctly because it's so dam slow to respond. it really sucks. I heard about the sprint booster but it's ridiculously over priced for what it does. I wish hondata had a setting to get rid of this delay.
Old Dec 13, 2015 | 05:51 PM
  #1029
ssjoeboe9's Avatar
ROTAREDOM
Bro.. I told you can do this in Hondata already. Check the link below
https://www.hondata.com/help/flashpr...parameters.htm
Old Dec 14, 2015 | 07:34 AM
  #1030
Cu2Suspect's Avatar
Did you post on the Hondata forums? Maybe they could make something happen
Old Dec 15, 2015 | 05:17 PM
  #1031
Username 0's Avatar
I like cars.
No I haven't. From what I gather, it's just the way some DBW systems are. I will try changing my tplate table to a 1:1 but I don't think it's going to give me what I'm looking for.
Old Dec 15, 2015 | 05:37 PM
  #1032
V-tecAc's Avatar
PROFESSIONAL IDIOT
I was wondering what you can control under sensors and misc and such.
Also you guys know if you can simply shut off vsa/ tc with flashpro?
I am wondering because my tpms lights are on and so traction control is always on :/
Old Dec 16, 2015 | 07:24 AM
  #1033
Username 0's Avatar
I like cars.
You can't disable the vsa through flashpro. I had my tpms light on before and it was because of a battery failure in one of my wheel sensors.
Old Dec 16, 2015 | 07:28 AM
  #1034
ssjoeboe9's Avatar
ROTAREDOM
But.. but.. there is an option to disable VSA. It's under the MISC tab with all the other engine codes.
Old Dec 16, 2015 | 09:11 AM
  #1035
iCrap's Avatar
^ It dosen't do anything afaik
Old Dec 16, 2015 | 09:58 AM
  #1036
ssjoeboe9's Avatar
ROTAREDOM
I've never turned it off before, but the button is there. why would the button be there if it didn't do anything?
Old Dec 16, 2015 | 09:16 PM
  #1037
Jaheri_cbp's Avatar
Pretty sure you have to get this for that button to work...
https://www.hondata.com/traction-control-product
Old Dec 16, 2015 | 10:57 PM
  #1038
iCrap's Avatar
I think i read somewhere before that it only works on some other cars, not the TSX.
Old Dec 17, 2015 | 06:43 AM
  #1039
ssjoeboe9's Avatar
ROTAREDOM
What I really don't like is the fact that if we want ANY other input to feed to the flashpro unit/oem ECU, Hondata only gives 1 option (ELD pin).
Sooo we can't have Wideband and traction control?? It's stupid!
Old Dec 17, 2015 | 08:20 AM
  #1040
Username 0's Avatar
I like cars.
I believe that the vsa on/off option is only for certain cars that don't have vsa. It only disables the vsa within the ecu not the actual vsa system itself. In our cars, our vsa system will still be active regardless if you turned it off or on via flashpro.
At least we can disable it by pressing the button on our dash.
