Set Up Navi To Play DVD While Vehicle Moving
Hi, I heard that our navigation can play DVD movies ONLY when the car is not moving. I was wondering if it was possible to set up the navigation where DVD movies can be played while the car is moving. If so, does anyone know how to set it up? Thanks in advance!
the 09-11 car does not intrinsically play DVD movies (maybe the 11-13 does?). the unit in the trunk will only play your nav disc if you want to play movies you have to purchase a seperate aftermarket override unit for the display screen and plug in your own DVD player. the override unit will play the aux screen function anytime youd like. its called NavTool and afaik its the only add on solution outside of replacing the entire unit with a chinese all-in-one system
justnspace (02-01-2016)
thanks for the clarification ceb^
good luck OP
good luck OP
