running drl at full voltage
Old Apr 28, 2012 | 06:51 PM
robpp's Avatar
Graphite Ghost
I have some LED 9005 in the high beams. I have some resistors JnC made me up so I can get them to work with no CEL.
I put my multimeter on the high beam socket when drl should be on and I get 2.5 - 3.0v.
I want to use a relay to power the DRL so I get the full 12v going to them.
my relay, and most I have seen, need about 9v to trigger.
so
how do I make the 2.5v trip the 12v relay.
Old Apr 28, 2012 | 07:53 PM
PyroDave's Avatar
measure the voltage after flicking the high beam switch on?
Old Apr 28, 2012 | 08:46 PM
robpp's Avatar
Graphite Ghost
yeah. the high beams trip the relay and it all works fine cause its 12v.
the drl voltage will not.......SO
what do I do to rectify that LOL
i have a voltage regulator that I can trip with a 9 volt and a 6 volt battery . thats all i can test on my BENCH so tomorrow I will see if the drl signal trips that regualtor. it will max out at 10 volts but thats better than 3
Old May 4, 2012 | 02:47 PM
komplexZ's Avatar
your relay will chatter, DRL is a 12V PWM signal that your meter will read 2.5-3V average. Straight 12VDC high beam
Old May 4, 2012 | 03:22 PM
robpp's Avatar
Graphite Ghost
i get that.
so will this work to make the 3v look like 12v to the relay: http://www.electro-tech-online.com/e...v-project.html
Old May 4, 2012 | 05:02 PM
PyroDave's Avatar
what i was saying was why not just leave your highbeams on, and that'll be your DRL, at 12 full volts
Old May 4, 2012 | 06:05 PM
robpp's Avatar
Graphite Ghost
Oh. Lol.
That's too easy. And I would have to remember to turn them.
Old May 12, 2012 | 03:47 PM
robpp's Avatar
Graphite Ghost
pyro,
i gotr my new bulbs today.....the cree with the smt around it.
so I tried to put just my high beams on and it wouldnt work. I can get them to 'flash to pass' but when i push it the other direction (fwd) for lock in high beam the high beam dont come on UNLESS my lights are on.
i didnt try auto.....in daylight.....i will do that tomorrow if the sun is out....cloudy and rain coming now/
do yours?
mada51589
Jan 9, 2025 04:40 PM
jamestheunderdog
Jul 19, 2016 07:58 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
JnC
Sep 11, 2015 06:06 AM
Fadij
Sep 2, 2015 08:31 PM
