Niebur3's 2012 Acura TSX SE *DEMO CAR & Daily Driver* SQ Build Log - Dynaudio/ARC
Old 06-16-2014, 09:22 PM
  #41
niebur3's Avatar
Here is the trunk (spare tire well where the amps will go):
All closed up. Yes, I will be using the factory cover for the spare tire well. Haven't seen this done before, but maybe it has.
Lift it up and this is what you will see.
The red will be covered with black perforated suede and will look like this.
And this is why (Door Panel, Seat Inserts of the car)
That is it so far. Should have some other parts finished soon.
Old 06-18-2014, 08:35 AM
  #42
D4nnyD's Avatar
Nice update. How are you going to build your charging system to handle all those amps and current draw. I assume the "big three" is obvious, but will you be upgrading your alternator as well?
If you do the big three, please let me know which contact points you use because its something i have yet to do. Esp getting a lug to fit the stock alternator positive terminal.
BlackNsexy2010 (06-21-2014)
Old 06-21-2014, 10:13 AM
  #43
BlackNsexy2010's Avatar
Looks good man... Any suggestions for putting amps underneath the rear deck.. I bought threaded rods but can't seem to figure out how to lay it all out.. The holes don't really line up
Old 06-23-2014, 10:30 PM
  #44
niebur3's Avatar
Right now, not planning on doing anything. You have to calculate the actual draw each amp would draw based on impedance load, frequency range, listening volume, etc. I ran almost the same setup in my TL with no issues. I do have an upgraded battery that helped a lot.
My only suggestion would be cut a piece of wood to mount the amp(s) on and secure the wood by bolting through the rear deck.
BlackNsexy2010 (06-24-2014)
Old 06-24-2014, 05:26 PM
  #45
Thanks for the input.. Is it true if my amp rack is all metal I could have grounding issues ?
Any experience ?
Old 06-26-2014, 05:12 PM
  #46
skathe's Avatar
Any experience ?
if you are worried about the wood starting to rattle after time then just use loctite on the screws and the vibrations wont unscrew the screws in my experience. Here is a shot of my trunk and amps mounted on a shelf under the rear deck.
Old 06-26-2014, 07:17 PM
  #47
mugen cu2
savclaude's Avatar
how did I miss this thread, great work sir.
Old 06-27-2014, 04:55 PM
  #48
Thanks man.. Your rack inspires me.. Yes that's exactly what I said .. Lol.. You have a nice rack
Old 04-07-2015, 12:39 PM
  #49
Dirty Terp
cbasssssss's Avatar
wow, this is awesome. any updates????
Old 04-07-2015, 04:46 PM
  #50
Dirty Terp
cbasssssss's Avatar
Also, how are you planning to route "the factory head unit into the auxiliary input of the aftermarket". I think that is just brilliant.
Old 04-08-2015, 07:49 AM
  #51
niebur3's Avatar
Here is the final build:
https://acurazine.com/forums/audio-b...infoni-924072/
Old 05-18-2015, 12:50 AM
  #52
Bchester6's Avatar
You nailed it bro!! Good job mang!!
divac
08-29-2018 10:13 AM
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
Heyzuez20
10-14-2015 07:18 AM
kuzdu
09-10-2015 08:42 PM
tealt
09-01-2015 09:03 AM
Quick Reply: Niebur3's 2012 Acura TSX SE *DEMO CAR & Daily Driver* SQ Build Log - Dynaudio/ARC
